Results 1 to 5 of 5
Thread: Dakota Digital Instruments
    Has anybody installed Dakota Digital Instruments? I am wondering if there is any problems with space behind the dash? Does anybody have any pictures of the install?
    33 Hot Rod #664 BrentM's Avatar
    May 2013
    Here is how much clearance there is behind the dash. I have my auto meter gauges carefully placed and it is tight but doable.
    Once you get over the master cylinders there is plenty of room. Here is my gauge layout.
    Wow, I didn't know it was that tight. Thanks the pictures help a lot. Now I know why people put the instruments in the middle.
    By the way. Nice set up. That's how I would do it also. So you can read the gauges through the steering wheel.
    May 2013
    Quote Originally Posted by vchirasello View Post
    Yes the last picture is my view from the drivers seat. The fuel and volt gages are going in the middle. The gauges are mounted to the aluminum panels that are removable in case I need to get back there. They will eventually be powder coated satin black.
