Thread: AN O-ring Oil Fitting
    Senior Member Bren's Avatar
    Dec 2013
    Build: Sugar Land, TX; Live: Madison, WI
    So, I think I've found the source of my oil leak: my pancake style thermostat inlet and outlet are -10 AN O-ring fittings. I have just regular -10 AN fittings on there. Can I just add an o-ring to the fitting I have or is it a special fitting?
    Build Blog
    #8203, carbed 427W (611 hp), TKO 600, IRS
    Delivered: May 27, 2014
    Mechanically "Complete": October 1, 2014
    Dec 2013
    Never mind. I bit the bullet and bought new fittings. With expedited shipping, of course...
    Build Blog
    Give us an update when it's fixed. I am no expert by any means but have not heard of an 'o-ring An fitting'.
    Conesus, NY
    O-ring AN have a straight cut thread instead of NPT on one end and use an O-ring to make the seal when tightened. It has a regular AN fitting on the other end.
    Chuck Krueger
    MK4 Kit - Picked up 4/5/14, Complete Kit, 3-Link, Wilwood upgrade, Coyote, TKO 500, First Start 7/25/15
    2000 C5
    2003 C5 Z06
    2007 C5 Z06
    O'Fallon, MO
    Its an orb fitting, (o-ring base)
    Dec 2013
    It has AN sized threads, but instead of a flare to make the seal, it uses an o ring.
    Build Blog
    Ok, got it. I wasn't thinking of the other end of the fitting.
    Dec 2013
    I replaced the regular -AN flared fitting with an o-ring fitting and that has solved the leak.
    Build Blog
