Results 1 to 40 of 58
Thread: Rear Fender Brace, Zero Decibel Motorsports
    Mechie3's Avatar
    Indianapolis
    Zero Decibel Motorsports Rear Fender Brace
    What:
    Adjustable brace to help set and maintain rear fender panel gaps.
    Why:
    The rear fenders/side panels are supported in three main areas: At the rear bumper, at the shock tower brace, and around the entire cockpit area. In between the shock tower and the rear bumper is a rather long unsupported length. Using just the two FFR supplied bolts on the shock tower can put excessive stress on the side panel lip causing it to crack. Getting good panel gaps can also be difficult. With one end having a right hand thread and the other having a left hand thread you can easily pull the side panels together or push them apart with a simple twist of the main shaft. Panel gaps can be easily set before drilling holes into the shock tower brace.
    Cost:
    $68
    Shipping
    $15 in continental US. Ships in a new shipper tube for lowest costs.
    Includes
    2 laser cut and tumbled aluminum brackets
    1 RH threaded stainless steel rod end (with teflon sleeve) and nut
    1 LH threaded stainless steel rod end (with teflon sleeve) and nut
    1 shaft with RH and LH threaded ends
    2 Stainless steel screws and nylock nuts
    Uses 3/16" rivets supplied by FFR to attach to body
    Prototype version with 1 anodized face (finished version is tumbed)
    Prototype installed at trailing edge of engine cover.
    Check out my new website!
    Senior Member AZPete's Avatar
    Yes, Craig, I need a rear fender support! PM sent.
    Port Charlotte, FL
    Ill take one Craig.
    Henry
    Tucson, AZ
    I'll take one also
    - Aaron
    Mechie3's Avatar
    Indianapolis
    All paid orders shipped this am via priority USPS. When you open it, one end of the shaft has blue tape and one of the end assemblies has blue tape too. These are the left hand threaded sides. Just in case you cross thread something and want to chase it with a die or tap the rod ends are 1/4-28 thread.
    I will want one of these. How about a donut spare tire mount above the transaxle?
    Craig, I received my fender brace and it's perfect! The finish is even better than your photo. Soon I'll start putting body panels on and this brace will hold the rear fenders. Thanks!
    Pete
    Mechie3's Avatar
    Indianapolis
    Excellent! I was worried that some of the shafts had gotten some small scratches on them.
    It looks good to me and I'll undoubtedly add my own scratches when I install it.
    Tucson, AZ
    I didn't look mine over for scratches since it will get plenty of those anyway Got mine as well and look forward to installing it when the time comes.
    Mechie3's Avatar
    Indianapolis
    Still have a few of these left.
    Jul 2012
    Encinitas, CA
    I was on the fence since I'm still far off from body mounting, but I'll go ahead and get one. I'll paypal you.
    How is it possible to mount the rear body panels without this brace? Yesterday I was struggling to hold the sides to the bumper trying to get clamps on, which I finally did, but then one clamp slipped and I started over. I tried this twice before I remembered that I had bought a rear fender brace from Zero Decibel - duh. I mounted the brace and admired the clever design and how it easily pulls the sides in precisely. Next, I'll mount the engine cover and adjust the sides to fit. When I bought this 5 weeks ago I thought it would be good because Craig made it but I did not realize how essential it would be.
    To those following: Before you mount the body panels, get the rear fender brace or a good supply of Valium.
    Mechie3's Avatar
    Indianapolis
    Haha! Thanks Pete.
    Fred did discover an issue with this brace though. If you mount it where I did, it interferes with the trunk hinges. I didn't have mine mounted at the time. You can mount it further back and it won't interfere, but then it's no longer tucked in.
    For those that already bought this, I have a new hinge designed. I'm just waiting on the CNC to be fixed so I can make up new hinges and send them to everyone that already bought this. The other option is to use it as a 1 time tool to mount it and then remove it (not a big fan of this, as it becomes an expensive 1 time tool). As a bonus, the new hinge gets rid of the stamped OEM steel piece. It looks a little out of place with the rest of the car.
    Senior Member Quiny's Avatar
    Massachusetts
    Sounds good, thanks for the update
    Jan 2012
    Darn wish I saw this last night. I just ordered new oem hinges. Still want to get this brace though.
    Jul 2012
    Encinitas, CA
    Sweet... that's generous!
    Senior Member metros's Avatar
    NoVA
    I'm in 100% once you have gen 2 completed.
    Senior Member Triathletedave's Avatar
    Calgary
    Do you still have any fender braces for sale? I should order one if you do. Thanks.
    TriguyDave
    818 noobie builder
    First start: Sept 28, 2014
    Go-carted: Oct 4, 2014
    Registered and Street legal Sept 30, 2015
    Calgary, Alberta
    Mechie3's Avatar
    Indianapolis
    I have to order some more parts (mostly hardware) but can get them if people want them AND they understand it can't be mounted where I mounted mine without modifying the trunk hinge or buying the one I'm going to make (only those who purchased the brace prior to Fred discovering the issue will get a free one).
    Jan 2012
    How much extra is the new trunk hinge going to run us?
    Houston
    The only way I could use the OEM Hinges
    I should have mentioned...
    Hope this helps especially with your redesign too Craig.
    The only way I could get my stock hinges and rear cover panel to work was to add 3/8" spacers between the hinges and the Chassis. That is I moved the hinges 3/8 towards the rear.
    After that getting the alignment, easy opening etc. was comparatively easy. (Before that....Impossible!)
    fred
    Mechie3's Avatar
    Indianapolis
    Thanks Fred!
    07Fireblade: If it can be accomplished with simple spacers, then likely the cost will go up a minimal amount ($5?). I'd have to do the math. Simply round spacers I can make myself, a nicer plate with rounded corners and and two holes will have to made at a third party shop, but I can't imagine they would cost much either.
    I still intend to make the nicer version of the trunk mechanism for everyone that has already purchased it since they purchased it without the knowledge that other things had to be changed.
    NoVA
    Any updates on the new version?
    Wanted to bring this back onto the front page bc I think it'll be extremely useful.
    Mechie3's Avatar
    Indianapolis
    I know GUNS installed his yesterday (or two days ago) and liked it.
    I'm still working on a solution. I didn't like my first prototype for several reasons. I'm halfway through my second revision. I found another problem (same as freds) in that the OEM/FFR latches don't work for me even without the brace. The trunk bracket is too far back to reach the mounting point.
    Mechie3's Avatar
    Indianapolis
    Some updates:
    Last week I tried to put my hinges on (no brace) and it wouldn't fit. Freds mentioned he had to space his out. Last night, I attempted the same thing...and they fit. The only difference I can think of is I bolted it to the lid first while the other screws were loose, then tightened those up. Voila, it works! I don't drink either, so I can't say I was drunk the first time I tried fitting it.
    Moving on, I put the brace back on. In the closed position I had about 3/8" clearance. I could just stick my thumb between the brace and the hinge. In the open position it did hit the OEM stamped metal piece. I just hacked out a notch with a sawzall to prove the concept. You can cut it and round the edges to look nice. This allows the lid to open up all the way.
    That said...
    1: I still plan to make the billet hinges for the 4 or 5 people that already bought one of these. Of course my record keeping is terrible so I'll have to search through my paypal statements to see who that was.
    2: I will now offer these again for those who want them as well with the understanding that you have to notch out the hinge to work and that it's a tight fit and, if you don't line up your brace or body well, you might need to add washers underneath the stamped metal part.
    Check out my build thread for the latest hinge design I came up with.
    Mechie3's Avatar
    Indianapolis
    Just realized I didn't post any of the pictures I took last night.
    Trunk lid closed:
    Trunk lid removed, closed position:
    Trunk lid open:
    Jul 2012
    Encinitas, CA
    That said...
    I'm one... that's very generous of you, Craig!
    Looks great!
    NoVA
    Love the new hinge design.
    With this newest update on fitment - does this mean you're going to keep the current design and recommend the above modification of the hinges to make everything work together? Or are you still planning a revision?
    Mechie3's Avatar
    Indianapolis
    Stay with the current fitment. There's nothing I can change to eliminate the need to notch out the hinge aside from making all new hinges.
    Senior Member Doowop's Avatar
    Denver, CO
    Craig, I'm assuming the trunk issue is just on the S, not the R? My kit is shipping tomorrow, so....
    Mechie3's Avatar
    Indianapolis
    If you don't use hinges there is zero problem. Not sure if the R forgoes hinges all together.
    If you do use hinges, you need to be careful with your placement. I'd recommend bolting the hinges to the frame with the FFR curved bracket and using that to help locate the brace.
    Freeport, ME
    make a trunk prop and don't open the trunk so far...
    Dan
    NoVA
    Gotcha, but these should work beautifully with your billet hinges?
    Mechie3's Avatar
    Indianapolis
    Pretty much.
    NoVA
    Excellent, awaiting the package deal for all 3 hinges, rear fender brace, and t-shirt.
    Mechie3's Avatar
    Indianapolis
    Placing an order for more of these. Parts will be available soon.
    Massachusetts
    Any news on the second generation hinge?
    Mechie3's Avatar
    Indianapolis
    I have one on my car?
    That's about it so far. Been playing catchup with a few other items and had to finish some one off SEMA car items. I need to make 2 updates. One to reduce weight, the other to provide more clearance to account for car differences. I hope to start making the 4 or 5 next week for those that need them.
    Would love to have a hinge system that would allow for checking the motor oil without removing pins.
