[ATTACH=CONFIG]33919 Block requires about 1/4" relief under the oil filter pad
[/ATTACH][ATTACH=CONFIG]33920 Starter appears tighter than it is.
[/ATTACH]IMG_20140920_145643_790 (361x640).jpg Plenty of room next to oil pan and above exhaust.
These pics show orientation with a 3/4" thick adapter. Note starter gear height. The flywheel used requires a 1" thick plate. The RM8076 has 5 bolts common to the early hemi, however, the dowels do not align. That will require drilling the plate, not the bell.
