I completed the rear alignment and it came out very good, all measurements completely repeatable. On to the front. Everything seemed to be going well until I got to the camber adjustment. With both sets of threads bottomed out on the UCA I can still only get to 0 camber. Caster is fine at 3.5 degrees but trying to get negative camber is impossible. I am using the aluminum lower control arms and had no issues with fitment. It seems like I either need to move the LCA out or cut the threads on the UCA. Even if I cut the threads I think I will still have remove at least one jam nut on the short side or cut the threaded adjustment sleeve. Am I doing something wrong? I did make sure the cam bolt on the spindle was all the way negative, it was worse were I had it set at mid cam.
