Page 2 of 2 FirstFirst 12
Results 41 to 48 of 48
Thread: Chassis #111 2006 STi with Blouch 2.5XTR First Drive Video
    Leesburg, VA
    Quote Originally Posted by sponaugle View Post
    Congrats on getting it up and running!
    I assume that the extra length on the STI front axles didn't cause any problems? I am just about to drop my transmission in and I'll be using those same axles with the stubs changed over.
    Jeff, what's your plan for changing the stubs? You're planning on using a wrx 5 speed with sti axles right?
    Research Calibrator sponaugle's Avatar
    Portland, OR
    I am using the STI axles with the STI Rear Stubs (outer), and STI Front Inner Stubs. I had my 5 speed converted to accept stubs by Andrewtech during the buildup.
    Puyallup, WA
    Quote Originally Posted by Turn In Concepts View Post
    Looks about right to me, but without units on the boost plot and knowing what fuel is being used it's tough to say.
    We had one on our dyno last week and really didn't see a huge increase in power over an AWD application. It was maybe 5% higher if i remember correctly.
    Tony
    The tune is based on 91 Octane from Safeway
    Tony - Do you see an issue with dyno numbers for a RWD car performed on a 4WD Mustang Dyno?
    Puyallup, WA
    Jeff - Yes, i used the STI axles as you described. I ended up adjusting my links so i have at least a 1/4" lateral travel in the axle to ensure there was no binding.
    Portland, OR
    Awesome. Great to see your car making noise! I may have to come up and see it in person.
    Puyallup, WA
    You are more than welcome to. Working on mounting the passenger seat in.
    Im also going to attempt to install and integrate the STI center console. It looks very promising.
    south-central CT
    I am not trying to insult anyone's intelligence. You asked.
    An excerpt from this technical article by Stoptech:
    Factors that will increase front bias Factors that will increase rear bias
    Increased front rotor diameter Increased rear rotor diameter
    Increased front brake pad coefficient of friction Increased rear brake pad coefficient of friction
    Increased front caliper piston diameter(s) Increased rear caliper piston diameter(s)
    Decreased rear rotor diameter Decreased front rotor diameter
    Decreased rear brake pad coefficient of friction Decreased front brake pad coefficient of friction
    Decreased rear caliper piston diameter(s) Decreased front caliper piston diameter(s)
    Lower center of gravity Higher center of gravity
    More weight on rear axle Less weight on rear axle
    Less weight on front axle More weight on front axle
    Less sticky tires (lower deceleration limit) More sticky tires (higher deceleration limit)
    I have no issues with it per se. The dyno could just be decoupled though to run just the rear.
    Tony
