Keith, I love your work.
/begin hate
But, I've got a whole gallon of Hate-orade for the Pink and Blue.
So bitter tasting!
/end hate
How many guys you got working on the car?
Fast Cars, Fast Women, Fast Haircuts!
Whenever my girl peers over at my screen and sees the pink she makes it a point to say how cute it is. We usually end up in a fight over it
Your build is pretty tight, look forward to seeing it next month.
In my experience, it seems that the false misfire code from having a lightweight fly wheel actually happens when pulling off throttle, or when the AC kicks on. Not when you're revving the engine up while on-throttle. Similar theory to yours but the reduced flywheel inertia allows the engine to slow down more between ignition pulses so the ECU thinks it's misfiring.
An actual misfire would behave the same way where RPM's would drop mid-cycle due to a loss of an ignition pulse. With a light weight flywheel, accessory loads can overcome the rotational inertia and replicate the behavior of an actual misfire by having the engine slow down more than expected over a single revolution of the engine. The ECU then assumes there was a loss of an ignition pulse and throws the code for the cylinder that was up for it's bang when the RPM drop occurred according to the crank position sensor.
Edit: The reason this happens more on the 2.0L engines is due more to the lower sample rate of the ECU as the 2.5L WRX and STI in the US all have 32bit ecu's while all USDM 2.0L models ran on 16bit setups. The false misfire codes still happen on STI's, my bud has an 07 STI with both a lightweight flywheel and lightweight standard size crank pulley and he gets codes when in 5th gear pulling slightly up hill when the AC kicks on as well.
Nice shot... looks great! (still trying to dig the pink, though). Will the intake fit there with the body on, or is that just for g-carting?
What's the tab that sticks up just underneath the Sparco lettering?
Zero Decibel Motorsports
Check out my new website!
I like the CAI location. Finally, somebody using the side vents for something. Can't dig on the pink. Carry on.
"Scotty, give me all the TRACTION she's got!" Pictures of what I drive till 818R is finished
Track Car Journal on IWSTI (with build info)
This is Keith's office assistant. He's in the hospital, he had a heart attack. Turns out the shock of you FINALLY saying something that wasn't negative just pushed him over the edge even with the slam at the end. Don't worry scrote, you'll smile one day and learn not to hate.
I'll be praying for a speedy recovery, God bless...
Dan
That's intense. I wish him a speedy recovery. Get better soon Keith!!
I think/hope that was a joke on Keith's part.
818R For Sale!
818R Sale Thread
PADI Master Scuba Diver Trainer, PADI TecRec Gas Blender Instructor, Operations Manager - DNS Diving, Grand Cayman
If your joking it might be nice to clarify that
When we say to our customers "if there is anything you need, please ask," we mean it.
iWire Subaru Wiring Services
Over 100 Custom 818 Wiring Harnesses Built
http://www.iwireservices.com/factory...18-wiring-kits
[email protected]
I didn't know I could bring on a heart attack. I like to think that I had a little help.
Too bad Keith missed my other positive comment, "I like the plumbing work." and an off-hand compliment when I said "I don't think you are delusional." I do like the blue color, BTW!
Might just be SEMA looming. Poor guy.
I promise to lay off. Get better soon.
I lol'd.![]()
That killer B oil pan sure is dangling below the frame, you worried about speed bumps at all?
Also, yeah I'm ok. It was a bad joke.
Here's the requested video of some neighborhood lapping.
https://www.youtube.com/watch?v=w7Pq...ature=youtu.be
The location of the brake bias valve gives me ideas.
Same location as in my challenge car, will be putting the one that came with the kit in the rear (since its just a splice in the line running down console and if needed will install one on front. There is not a lot of console space as I have the emergency brake there, shifter, bias valve and fire extinguisher pull, no room for cup holder in the R
Tony Nadalin
2018 SOVREN Big Bore Champion
2012 ICSCC ITE Class Champion
818R Build in progress
Tracked May 27/July 26, 2017
Build Completed Winter 2021
Acres. The body is 6-8" away from the frame right here, hell you could route the intake back into the area above the fuel tank if you wanted.
This is semi-temporary. I don't like that if I was to get blasted in the side right there it could cut a fuel line. Worst case scenario I know but I'm going to move them after SEMA. Right now everything is being done fast, simple, and shiny. There will be a 2.0.
Car is looking nice. Wish I could make it to SEMA, seems like 2014 is the year of the 818.
