So, I have to point out something.
The location of the driver in your door, it is mostly pointed into the back of the door panel. Now, you might not care so much, which is fine, of course.
With a little more work, hah hah, they could create a new mount for the driver and use the new thickness of the panel to be able to get it away from the bar inside the door, therefor being able to put it into a new position pointed out the hole. You will get a much better sound out of those Hybrid's.
You know I love you.![]()
