Results 1 to 4 of 4
Thread: Braking Issues
    Aug 2012
    Fort Worth, Texas
    Braking Issues
    Taken my recently completed coupe out for several test drives. Braking performance leaves a lot to be desired. I have a firm pedal but it is like the pads are not engaging the rotors. I have the FFR supplied Willwood brake pedal set up and the small chrome brake reservoir. Rest of the brake package is the standard FFR package that came with the coupe. Any thoughts....
    Maricopa AZ
    Give me a call at 520-494-2745 sometime and we can talk at length about your current system and how to make it better.
    Senior Member mjazzka's Avatar
    Jun 2014
    Katy, TX
    Now that's service!
    My first thought is better pads since I assume you have the stock stuff that usually comes w/ the calipers. I started w/ Hawk pads and found the HPS to be setter than stock and the HP+ better yet. The HP+ do dust more though. Have you tried adjusting the front to rear balance yet?
