Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 161 to 200 of 393
Thread: nkw8181's 818 build thread
  1. #161
    nkw8181's Avatar
    Dallas, TX
    Also I let my alternator fall off a chair and busted it up. Thoughts on how to proceed? buy used? buy new? If I buy new should I get something different? Can it be fixed?
    Nolan
  2. #162
    Suisun City, CA
    It's fine. That only serves as a guard to keep things out.
    818S - #67 (SOLD IT!)
    Delivered: 18 November 2013
    Go Karted: 29 December 2013
    Finished: NEVER!
  3. #163
    Quote Originally Posted by nkw8181 View Post
    From what we can see in picture, it is good to go.
    The copper wires on the inside are covered with some enamel insulation. Do you have any scratches on the wire insulation? If so, send me a close up picture to look at. You can buy some brush on insulation if necessary.
    PS If you decide to take it apart. The is a trick to putting them back together. There is a small hole that you can put a stiff wire into hold the brushes out of the way during reassembly. Very difficult without this.
  4. #164
    Senior Member Rasmus's Avatar
    Las Vegas, USA
    Alternator should work fine. Don't stick your fingers in there while it's running.
    Fast Cars, Fast Women, Fast Haircuts!
  5. #165
    Mechie3's Avatar
    Indianapolis
    Take it apart, grind off the sharp edges. paint it, put it back together.
    Zero Decibel Motorsports
    Check out my new website!
  6. #166
    Suisun City, CA
    I think Rasmus did this to his and saved like 5 grams?
    Finished: NEVER!
  7. #167
    Apr 2014
    Quote Originally Posted by JeromeS13 View Post
    well.. he will NOW... lol.
  8. #168
    Las Vegas, USA
    Intentionally broke off alternator's case fins. Thanks for the idea Nolan. Saved 5 grams!
  9. #169
    Aug 2013
    Santa Rosa CA
    I bought one from ebay, less than a hundred bucks brand new. Clean saved 2 grams.
  10. #170
    Apr 2014
    Quote Originally Posted by Rasmus View Post
    I dont know what the stock alternator weighs on the subaru, but I know my old GM alternator weighed 14 something pounds, and my "lightweight" 40amp replacement alternator weighed 6lbs.
    but I am full of bad ideas.
  11. #171
    Feb 2014
    Asheville, NC
    Quote Originally Posted by MrDude_1 View Post
    The alternator-weight discussion happened on Rasmus' thread a while back, actually (here).
    My vote is on using it, but if you really need to get another one, they're found in junkyards very readily from what I've seen.
  12. #172
    Las Vegas, USA
    I dont know what the stock alternator weighs on the subaru.
    5.378 kg.
    It's a good idea Dude. Great place to save weight.
  13. #173
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    When you keep saying that, I cant decide if you are addressing him or quoting The Big Lebowski
  14. #174
    Las Vegas, USA
    Yeah, well, that's just, like, your opinion, man.
  15. #175
    nkw8181's Avatar
    Dallas, TX
    Whoo hooo the manifold is back together as well as having the addition of Craig's version 2.0 cooling bracket. The bracket has plenty of clearance. Also I've seen others using this picture hosting site so thought it might be easier then resizing on my home computer.
    http://imgur.com/a/x3GxQ
    Nolan
  16. #176
    Hindsight's Avatar
    Atlanta
    Looking good! You can copy/paste the links from the right side of the screen on imgur, into your message body so the pics appear in the message. It is more work.... since you have to do it for each pic, but just FYI. If you do it, use the link captioned "BBC Code".
  17. #177
    nkw8181's Avatar
    Dallas, TX
    So started installing the awic.
    I'm thinking of painting the intercooler the same as the manifold.
    Nolan
  18. #178
    nkw8181's Avatar
    Dallas, TX
    I started on the brake lines. For now I'm going by the "manual" but couldn't remember if there was anything vital to watch out for or that should be done different? Once it is done I may change it up but gotta start somewhere.
    Nolan
  19. #179
    nkw8181's Avatar
    Dallas, TX
    It has been a bit since I updated and I've got a bit done so here is an update.
    -modified clutch slave cylinder to allow the clutch cable to mount from the driver side.
    -Clutch and Brake lines ran (fronts still need mounting locations drilled)
    -Mocked up shifter
    -Installed shifter cables on trans
    Nolan
  20. #180
    nkw8181's Avatar
    Dallas, TX
    -Ran rear/side part of cooling system.
    -Installed radiator mount.
    http://imgur.com/a/jYbrF
    Nolan
  21. #181
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Looking good Nolan
  22. #182
    nkw8181's Avatar
    Dallas, TX
    Thanks Wayne as well as for your help.
    Nolan
  23. #183
    nkw8181's Avatar
    Dallas, TX
    Got some updates. the Radatior is temp installed (waiting on bushings), AWIC heat exchanger installed. I started putting the wiring in and very quickly came to the conclusion that I only want to do that once. That combined with the fact that as Wayne said it would be better to have it running before modding the harness. Run, mod, check if still running and repeat. I have a few holes to drill out for some rivnuts as well as checking the routing for the AWIC hoses. Wayne I am going to try running the hose under the aluminum tubing next to the brake/clutch lines. So my question is to all you fine builders out there is are there any other frame mods that I should undertake prior to powder coating? one addition is I still need to figure out how to finish out the center console. thoughts ?
    Nolan
  24. #184
    nkw8181's Avatar
    Dallas, TX
    Nolan
  25. #185
    QC, Canada
    Shifter: You put the plate under the alu tunnel cover? I didn't think about that, too late now, I have cut a huge hole already, just did this afternoon. It still looks good with the plate over the alu, I think.
    Console: Which center console version you got? The old FB is the new alu? I am currently installing it. What consumes most of the time is figuring out where I am going to cut to keep the shifter exposed. I might even bring the slope forward of the shifter, instead of just after. Anyway you can't leave it after, unless you want to cover most of the shifter.
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
  26. #186
    Your rear flexible coolant hoses need to be shortened or else they will interfere with the rear wheel well aluminum. Looking good though!
  27. #187
    nkw8181's Avatar
    Dallas, TX
    Thanks guys. GUNS will do on final assembly. Frank I have the sheetmetal one. Since ill be modding the harness anyway I'll do away with the vertical and make my own further back as Wayne suggested to me. It may be as small as a 5x5 in tunnel.
    Nolan
  28. #188
    nkw8181's Avatar
    Dallas, TX
    So as I'm taking things apart I wanted to see how a few more panels fit. Here are some pics of my engine floor panel. Is it to narrow? There is a gap on both sides. Also I have a second panel that is suppose to go from the engine floor panel to the diffuser. Anyone got pics of how to install the diffuser? While I'm at how about front splitter install pics?
    Nolan
  29. #189
    nkw8181's Avatar
    Dallas, TX
    How does this panel mount
    Nolan
  30. #190
    Chicago, IL
    I thought I saw the same side-gap on Chad's engine floor panel, so this just seems to be the way those panels are supplied. Not the best, but likely dictated by readily available sizes of the sheets. You might want to look at his thread (Plavan) for his mounting solution.
    Best,
    -j
    Executive Director
    The Community Garage
  31. #191
    nkw8181's Avatar
    Dallas, TX
    I'll check it out on reassembly. Got sidetracked "again" on my disassembly and installed some rivnuts for the center tunnel. Also the stock ebrake cable bracket came in so I placed the ebrake about where I want it. Will put the seat in tonight to see. I suspect that I will end up mounting that ebrake at downward angle under the aluminum to make the handle closer to level.
    Nolan
  32. #192
    nkw8181's Avatar
    Dallas, TX
    Can't forget pics
    Nolan
  33. #193
    nkw8181's Avatar
    Dallas, TX
    He is the solution I came up with for.my ebrake, which I am very happy with. I also got the rest of the car stripped. I have a "few" more rivetnuts to install from underneath (not fun). In the teardown temp installed the VCP trailing arms just to see how they look/fit.
    Nolan
  34. #194
    nkw8181's Avatar
    Dallas, TX
    I don't think my ebrake mounting will be moving :-)
    Nolan
  35. #195
    QC, Canada
    Nice solution, similar to one I had in mind. Which all changed once I saw your pix.
    Cuz that just showed me I am going to have 2 major problems: My ebrake cables are not like yours, I don't have those metal clips close to the end, so I cannot attach the FFR cable brackets to them. I don't know why, I ordered new 2003 cables from online subaru parts. That's going to be a challenge. Second thing, my shifter is much further back than yours, the shifter's rod is slightly backwards of the transverse bars in front of the seats. Which means my ebrake handle will most probably hit the shifter since yours is quite close already.
    Oh well, probably 10 to 20h to fix all this.
  36. #196
    Jul 2012
    Encinitas, CA
    Or get a Lokar ebrake!
  37. #197
    QC, Canada
    Don't want to hijack Nolan, but let's say he would see a different option (even though he has found and built something great already).
    The Lokar is 10in long, I don't know if that's going to fit. I don't even know how long my 2003 handle is.
    If the Lokar fits, great, but it's over $100+shipping and then you have to buy the cables probably, as it may not fit with the Subaru's for which mine don't fit anyway the FFR brackets. Another $100++shipping. But in the end if I can't do anything with the stock brake....... money will be the only option to fix it. And I don't think hydraulic drift brakes are good, they are not meant for parking.
  38. #198
    Jul 2012
    Encinitas, CA
    The Lokar is much smaller than the Subie and can be made to work with the OEM cables; that's the main reason I went for it. Nolan did a nice job fitting the OEM handle, but the Lokar is a relatively easy install if you want to avoid the fabrication, which is why I mentioned it. Wayne posted a how-to someplace, so if you any questions, lets take the conversation there.
  39. #199
    Is it just me, our does this thread load very slowly?
    I like your e-brake mod, may try something similar.
  40. #200
    Kirkland, WA
    What was wrong with how FFR tells you to mount the ebrake (as I'm about ready to do this and would like to know if there are issues). Also I noticed you ran the tunnel aluminum on to of the k-tuned shifter plate, how did you deal with the gap at the bottom (floor) since its like a 1/4 short now ?
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
