Results 1 to 9 of 9
Thread: brians 818s build
    Dec 2014
    north east ct
    brians 818s build
    this is my car pu 10-25-14 818s 03 wrx cruise power mirror wipers iwire harness
    Senior Member Tamra's Avatar
    Apr 2014
    Shelton, CT
    Wow, are you nearly finished already? You're going to have to post more photos and info than that!
    Tamra
    First autocross 3/29/15
    Member Louisromersh's Avatar
    Nov 2012
    Arvada, CO
    What Mirror's are you using?
    Dec 2014
    north east ct
    just figured out how to post pics will put some more up later that pic was from 11-30-14 I picked my car the same day you did I so you guys stuffing parts into your car and the kit was in the rental truck
    Dec 2014
    north east ct
    I own a junk yard so I went out in the yard a took 5 sets to try ended up w 93-97 Honda del sol
    Apr 2014
    Shelton, CT
    Are you going to get it registered? If so, when's your date for inspection?
    Tamra
    Dec 2014
    north east ct
    as i said i own a junk yard so i have 4 dealer plates and 4 dismanter plated i have not reg a car in 25 years
    What State/Country are you in?
    Dec 2014
    north east ct
    north windham ct
