Hello,
I have an issue with the location of the bottom of all 4 shocks on my Mk IV kit. It is a base kit with IRS. The donor is a 1994 Mustang GT 5 speed. I used the front LCA and spindles and the steering rack (which I de-powered) from the donor. I drilled the shock mount in the LCA in the location indicated in the instructions, as best I could determine. I also used the rack extenders and new tie rods from the kit. When I put the wheels on and put it on the ground to check ride height and base alignment I discovered that the tie rods hit the springs at full crank in each direction. The overlap was perhaps as much as 3/8". I drilled new holes for the shock mounts further back in the spring pockets in the LCA and mostly solved the problem. I will cut new spacers to move the shock to get the balance of the room I need.
In the back I installed the shocks with the spacers as indicated in the manual, short in the front and long in the back. When I put the chassis on the ground to check ride height I found that the spring cap hits the tube in front of the shock. I will have to fix that by cutting new spacers to move the eye of the shock.
I would like to know if these are issues unique to me or have others with IRS or donor front suspension had issues installing the shocks according to the manual.
Rick
