Results 1 to 2 of 2
Thread: Irs flex brake lines mk4
    mcwho's Avatar
    DeBary - Florida
    My kit came with 20" flex lines for the front and 17" lines for the Rear IRS. There is not much info on where the frame to line connector should be mounted. As with the solid rear axle cars it seems the 45 degree angle just forward of the rear suspension should be a good place. And is the 17" lines gonna be long enough.
    Thanks for opinions and feedback.
    Baghdad Bob
    Norton, MA USA earth
    I would mount it in the same spot.
