Results 1 to 4 of 4
Thread: Gas line leak - Faulty Fuel line on FFR supplied pump bracket
    Harley818's Avatar
    Vancouver BC
    Thought I would throw this out there if anyone else has a problem with the FFR supplied fuel pump bracket and tank seal.
    I had a frustrating time trying to seal the pump line. Wouldn't seal with the white FFR quick disconnects, wouldn't seal with 5/16 line clamped directly on it, wouldn't seal with a smaller size 1/4 in line clamped directly to the line.
    Turns out there was one or two pinholes in the ridge that is meant to hold the quick disconnect onto the fuel pump line.
    I cut the tube off just upstream of the ridge, and replaced the 5/16 fuel line clamped directly to the fuel pump line. No Leaks now.
    Hope no one else has this problem, its a quick fix once you find the leaks...... but now my garage smells like gas.
    Harley
    Bought 2002 Donor Jan 2014
    First Start Jan 18, 2015
    First Drive Feb 14, 2015
    Harley,
    That line has 45psi in it. I think it is very important to have a barb or bead on the tube. If you don't the hose might blow off shooting a lot of gas all over the place.
    Harley818's Avatar
    Vancouver BC
    Good point Bob.
    Not sure how I can do it though, other than asking FFR for a new pump bracket assembly.
    Any other ways you can think of?
    As you can see, I have two clamps on it, and its on tight, but you are right.... its not as safe as it could be
    Harley
    Good point Bob.
    2 options I can think of.
    1. get a pump assembly from someone that used a boyd tank.
    2. Tighten on a 5/16 compression fitting on the tube. Then remove the fitting. The compression ring will serve as a bead. Cut off the nut or not.
