This thread is about the Camry lights, not the headlights in the new nose.
I've searched and found very little about headlights, so I'm starting a thread that might be easy for those following to find.
High Beam: The manual says to use the high beam socket and bulb from the donor but I don't have those (AJW crate). Should I buy Subaru sockets & bulbs? Will they fit the headlights, which I think are Camry? Or buy Camry socket & bulbs . . . part numbers?
Aiming: The headlights supplied by FFR have very little adjustment possible even after I added a turn buckle at the bottom. It appears we are all mounting the headlights at different up/down and left/right angles but can the headlight beam be aimed to specs?
Eric, ehanson007, said to buy aftermarket projector headlights, like Spyder, which have aiming adjustments. Maybe before I buy sockets and bulbs for the supplied headlights I should upgrade the headlights. To find those I should search for Camry replacement lights, right?
