Ran to Part Source at lunch and picked up some parts..
4x Brake rotors
1x Front Brake Pads
1x Rear Brake Pads
1x Set of new plug wires.
$750 over the original budget already :-) Let the games begin.
I called the dealership, the rubber grommet only comes with the whole e-brake cable for $170 (cheaper then the $250 for the brake assembly). He did give me a lead on a few other places to call.
Rubber parts that i need replaced are:
1x front brake piston boot (Complete rebuild kit purchased from dealership for $31.16, I bought 4 sets, 2 front, 2 rear)
1x Lower A arm ball joint boot (Will have to find from "Energy Suspension")
1x Tie Rod End boot (rear) (Will have to find from "Energy Suspension")
1x knuckle ball joint boot (Will have to find from "Energy Suspension")
2x Emergency Brake Cable Lever Rubber Cover (cant find anywhere for less then $170/side)
