![FormaCars](https://thefactoryfiveforum.com/attachment.php?attachmentid=62553&d=1483735916)
aeromotive pump
Has anyone had problems with the aeromotive pump that comes in the boyd tank? The one that came in the tank shorted out when I first put power to it. The new one sounds terrible and has blown the 15a fuse once but not again. I'm thinking I should do something before I bury this section of the car with interior.
818 builder
I have had no issues with this one or any of them in the past. It should not be blowing fuses. You sure you did t miss a ground in the harness etc. I mean you seem very competent but maybe you missed something
The first pump was a dead short, this one was just very noisey. The fue is between the relay and the pump, not much else there in 6 inches of wire
818 builder
Ask for another pump, say this ones noisy. It should be pretty quiet. Other than this your cars looking great man !
Getting a new pump is not a problem, I just wanted to know if this was a systemic problem. It will be a chore to change once the firewall, seats and floor pan are installed.
818 builder
Yeah I know all about that. My piss of junk supplied tank leaked after I got it all button up. I ordered Boyd and junked that tin.
Do you have fuel in the tank yet? Mine seemed a bit noisy when I was testing everything, but it was running dry. Once I had fuel in the tank it got much quieter.
Larry
That is why I think the first one failed, I tuned everything on with no fuel and I kind of seized up. The second was noisy until I got about five gallons in the tank. Hopefully it will work with much less fuel than that. In any case since no one else seems to have problems I will button it up.
818 builder
You need to keep half in there, lower than two gallons seems to cause issues
These pumps are not made to run dry!!! Immediate damage occurs!
I figured that, but 2 seconds is not long and needing a half tank of fuel is not that workable.
![Martin's Dent and Collision Shop](https://www.factoryfive.com/wp-content/uploads/2019/02/martins-dent-shop.jpg)
