Results 1 to 40 of 76
Thread: Interest Check: Rear Trunk Lid, Billet Hinge
    Mechie3's Avatar
    I got quotes back from the shops and have worked out pricing. Unfortunately the hinge base is a multi-setup part so the cost is higher than the flat plates (as expected) but drops significantly at quantities of 10 pairs. Kit would include all hardware needed, two bases (LH and RH versions), a straight drop arm (x2), and a curved arm (x2). Pieces aren't available yet, I still need to finish up the prototypes and deliver them to the product testers to ensure they work. This replaces the steel FFR arm and the OEM hood hinge that FFR has you cut up and reuse on the trunk. If you have the rear brace from me, these clear that brace.
    Cost: With 5 orders, cost is $275. With 10 orders, cost is $215. 15 orders cost drops to $200 (not as much savings in part cost between 10 and 15 as there was between 5 and 10) Due to the high cost of ordering all the parts, this will be setup as a group buy with 50% due when order is placed with the shop to ensure I don't get stuck with a few thousand dollars worth of parts on a shelf.
    Recent photos of the v3 prototypes:
    V2 on left, V3 on right (thinned up to save weight)
    V3 base in front, V2 base on back (altered to give more clearance with engine cover)
    Older photos showing rev 1 and rev 2 (gives a better idea of assembly)
    Bottom photo (top is the rev 1 proto), curved arm not shown.
    Assembly on the left (right is the rev 1 proto all hacked up)
    Zero Decibel Motorsports
    Senior Member Silvertop's Avatar
    Forest Lake MN
    If you can get a least 10 buyers, I'm in............. Just let me know when to pay.
    Senior Member metros's Avatar
    NoVA
    I'm in as well. With as happy as I've been with all the other zdm parts, I can't imagine you'll have trouble finding that many interested builders.
    rori's Avatar
    Tulsa, OK
    I'm in at 10 orders also
    Denver, CO
    i am in
    Oct 2014
    Redondo Beach, CA
    I'd like a set
    Jan 2012
    Surry Va
    I would like one of these would even pay the lower price to be a beta tester
    How about a hinge system for the engine cover?
    Dec 2014
    north east ct
    im in on ten to
    Leesburg, VA
    Count me in
    you can count me in for a set as well.
    Mechie3's Avatar
    Well, that's nine. Close enough to 10 for me. I'll have to get on finishing the protos. Home sick today so I'm behind again. Doh!
    10 here!
    Jan 2012
    I would be so in for these if I knew that they would be compatible with the hardtop. Unfortunately until that's confirmed I'm going to have to pass for the moment.
    Denver, CO
    Probably not. I plan to have both convertible and hard top. I anticipate both will have their own special brackets if we are lucky to have options from mechie for the hardtop version.
    San Jose, CA
    I'll help get to the 15 part order level then. I'm in.
    Sep 2014
    Count me in for a great looking hinge!
    May 2013
    Colombia
    I'm in as well.
    I'd also be in for engine cover hinges, and hood hinges if you were to make them.
    Port Charlotte, FL
    I'm in!
    Henry
    Forest Lake MN
    Quote Originally Posted by Speedy G View Post
    I'm in as well.
    I'm already in for the trunk hinges -- but I think I'd pop for these as well if they were available.
    Trunk, engine and hood, plz.
    San Jose, CA
    Definitely in for a hood hinge ...
    Member Hendow's Avatar
    Sep 2014
    Hey Craig,
    Before you sell out... Count me in too!!
    +1 on the engine cover hinge!!
    Mechie3's Avatar
    Lol, engine cover and hood hinges don't exist yet, just trunk hinges. Need to find some CNC time to finish up all my backlogged projects.
    San Jose, CA
    I knew that, just wanted to vote on the backlog :-)
    Yet.
    Plz keep on the to-do list for some day, hopefully in 2015... hopefully.
    Mechie3's Avatar
    3 hours in the shop after work and you end up with this:
    Freeport, ME
    Those look exactly like the set that I have...
    Dan
    Jan 2012
    Surry Va
    Nice work would look good in my trunk
    Mechie3's Avatar
    Test piece to go with the bases. New design saves another 1/8lb per side (1/4 lb total).
    Denver, CO
    When will you need deposits?
    Mechie3's Avatar
    After the product testers confirm fitment and I'm ready to place an order with the shop.
    Mechie3's Avatar
    One of the product testers had a successful test fit and sent me some photos. I placed an order for the bases two (three?) weeks ago. I'll get the latest set of curved arms quoted and then get them on order as well.
    NoVA
    Looks good! Sign me up!
    Senior Member Quiny's Avatar
    Massachusetts
    I was one of the testers, they fit so much better than the using the stock hood hinges. The panel lifts smooth and even not wobbly like the stock hinges . I even got a "that looks cool" from the wife.
    Denver, CO
    Looks awesome. Can't wait.
    Looks pretty good!!!
    They bolt on through the 2 small oval/elliptical holes (eyelets) close to the FFR bolts on the shock tower brace?
    Mechie3's Avatar
    It bolts in the same location as the FFR parts on both the trunk and the cross brace.
    Mechie3's Avatar
    Wondering who is still in for these. I got the quote back from the laser cutting shop and can go ahead and order all the parts now.
    Feb 2013
    Copperas Cove, Texas
    I'd love to get a set but $215 is pretty steep for my blood right now.
    -Jason
