started painting the last of the suspension components.
The ABS sensor connector brackets (grey) had to be sanded down completely as the paint would just flake off. Grey engine paint was used to respray, black brake paint was used for the ebrake mounting plates.
Started putting everything together with brake lube
Hardest part was getting the seals around pistons to seat properly, one how-to i watched showed the seals being pressed in on the piston however they don't seat properly that way. The best approach is to put the seal into place with a little brake lube to keep it stuck in there. Then lube up the piston and slide it into the boot, jam a few pieces of scrap wood in front of the piston to lock the piston into the inner seal. now use some compressed air to inflate the seal from the hydraulic hose inlet. This causes the boot to inflate and seat into both the piston groove and the inner groove. Now just repeat that 5 more times.
I also sanded the red paint of the corvette logo's on the calipers so they stand out. I really like the Corvette logos, decided to keep them.
