Page 2 of 2 FirstFirst 12
Results 41 to 73 of 73
Thread: K3LAG Electronics - Odometer Reset EEPROMs for sale
    Freeport, ME
    Pete, your PM box is full! PM me please
    Dan
    Mar 2014
    Hingham, MA
    Quote Originally Posted by K3LAG View Post
    If any of you want to power up your cluster out of the car to test your odometer it only takes two wires. On the green 10 pin connector on the cluster, put ground on pin 6 and power on pin 10. Be careful not to short to the adjacent pins. That won't activate the entire cluster, but is enough to power up the CPU and get the odometer reading.
    Larry
    I want to be sure from which side we are counting pins, I presume from the plug connector side?
    Ivan K0OSZ
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Quote Originally Posted by idf View Post
    Ivan K0OSZ
    Start counting from the pin closest to the center of the cluster.
    Larry
    Senior Member Tamra's Avatar
    Apr 2014
    Shelton, CT
    Will this work on a JDM v8 cluster?
    Tamra
    First autocross 3/29/15
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Quote Originally Posted by Tamra View Post
    Tamra,
    I don't know for sure. Can you post a picture of the cluster? If it is the same as one of the ones I have already done then I have it. If it's different, I can probably program one especially for your cluster, but you will have to take your cluster apart to be sure it uses the right kind of EEPROM. Also, I charge a bit extra for custom programmed ones.
    Oops, I was slow this morning. That's a STI cluster which uses a different EEPROM. I don't have the ability to do them.
    Larry
    Frankfort, IL
    Installed mine this morning. Piece of cake, and confirmed it shows as zero after powering up. I've never worked on a circuit board before but used a basic soldering and desoldering kit from amazon and it was no trouble at all. Took maybe a half hour even with my two year old watching over my shoulder. Thanks!
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Quote Originally Posted by billjr212 View Post
    That's the way to start training those future electronic engineers young!
    Larry
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    EEPROM sales will be coming to an end soon. I have 6 EEPROM04Green and when they are gone that will be it. I lost the virtual machine disk image that all the EEPROM images on it so I don't have the ability to program any of the others at this point.
    It's OK I was thinking I would wind this down soon anyway.
    So, if you have a '04 or '05 WRX as your donor and you want to reset to 000000 get one of the last six while you can.
    Larry
    USA
    This is a really great service, it's too bad that you can't keep doing it. I use an older netbook with XP with my programmer. You could buy a used XP machine on ebay or craigslist and keep doing it.
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Quote Originally Posted by Aero STI View Post
    I have a machine back up and running. The problem is that I lost the files that contain the images of the data for the EEPROMS. I could possibly regenerate the data if I got a hold of the appropriate clusters again or if a few people that bought EEPROMS from me, that haven't installed them yet, sent them back to me temporarily so I could copy them. The truth of the matter is that sales have dropped off dramatically. I haven't sold any for nearly two months so it's not really worth it to keep it up.
    Larry
    DFW, Texas
    Larry
    I would be willing to send you my 03 WRX EEPROM for you to copy. My build wont be done in a few months. I was planning on buying one of your EEPROMS, kinda bummed you might be getting out of it.
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Quote Originally Posted by NevaLift2Shift View Post
    PM'd you.
    Senior Member metros's Avatar
    NoVA
    I was also really hoping to get my cluster done. Haven't gotten to PMing you and asking if you'd do the whole install. I don't feel confident in the least in doing this type of soldering work on my cluster.
    I live in NoVA, so probably not that far from you.
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Quote Originally Posted by metros View Post
    PM'd you
    Senior Member EODTech87's Avatar
    Feb 2013
    Copperas Cove, Texas
    I dont need the chip that you sent me for a 2004 WRX so I can send it back if it helps out at all.
    -Jason
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Quote Originally Posted by EODTech87 View Post
    Thanks for the offer. I have several of that one left so I don't need it.
    Larry
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    I have been able to recreate the files for the Red, Blue and Yellow EEPROMS. Basically all the USDM models. I have 18 parts left that can be programmed with any of those three configurations. Once those 18 are gone I plan to quit selling them, so get them while you can!
    Larry
    Nepa
    any left for 05 cluster?
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Quote Originally Posted by Samiam1017 View Post
    Pm sent.
    Hey Larry,
    I noticed you have a metric option for a tach that has a 9k rpm gauge in the centre. Is there anyway that can be applied to a tach that has the 9k rpm gauge on the right and was for a 2002-2003 wrx and still get metric units? If I installed an american EEPROM into a metric speedometer do you know how well the km speedo and the odometer in miles would work together?
    Ian
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Quote Originally Posted by iblackwe View Post
    Hey Larry,
    Ian
    Ian,
    I replied to your PM.
    As I mentioned in the PM to you, the only way I could do it is if you removed your EEPROM and sent it to me so I could duplicate it and change the contents.
    Larry
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Now down to about a dozen parts left.
    Larry
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    I'm down to 10 parts left. I've decided to end this little venture at the end of this month. If you desire one of these, order by the end of the month. I will hold a couple of parts back in case anyone that has already purchased one runs into trouble.
    I'm not going anywhere so if you have any questions let me know.
    Larry
    Denver, CO
    I need one for my 2006 wrx cluster.
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Quote Originally Posted by bbjones121 View Post
    pm'd you.
    Denver, CO
    pm'd you.
    Payment sent. Thank you very much.
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Only one week left until the end of the month. If you want a EEPROM to reset your odometer order before the end of the month.
    Larry
    Feb 2013
    Danvers MA
    Hi Larry:
    I'd like one for my 2006 WRX.
    Thanks... Jeff
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Quote Originally Posted by JeffS View Post
    Hi Larry:
    Thanks... Jeff
    PM'd you
    Harley818's Avatar
    Vancouver BC
    Hi Larry,
    I thought you were getting out of this last year, and I thought you were out of the ones I wanted, but thought I would at least check on your status and availability.
    Not sure if the ones you have yet are compatible with a Canadian 2002WRX. If so, I'm interested.
    Harley
    Bought 2002 Donor Jan 2014
    First Start Jan 18, 2015
    First Drive Feb 14, 2015
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Hi Larry,
    No, I don't have any of the metric (Canada or others) at this point. I had some of them at one time, but they got lost when my virtual machine got trashed.
    Larry
    Mar 2014
    Silver Spring MD
    Larry,
    My son installed your odometer reset chip last night. (He studied engineering for two years before switching to math.) The new chip works perfectly. The odometer now reads "0." This was an easy job and the result is well worth your fee and effort.
    Thanks again.
    NoVA
    I would recommend Larry to any builder. Great communication with his customer and end product as expected.
