Hi everyone. Planning my 818R build and I'm researching my wheel/tire setup for the track (my 818R will not be driven on the street).
Everyone seems to be running 17s in front and either 17s or 18s in the rear. This leaves few choices for DOT-R rubber that will fit. From other posts and my research, it appears that the fronts are the biggest challenge. Finding a tire that has a diameter of 24 inches or less AND is also made in an appropriate size for the rear. Only thing I've found is the same as what is listed in the 818R supplement from FFR, and they both seem to still rub a bit in the front from what I can gather.
(DOT-R suggestions from the 818R supplement from FFR)
Hoosier A7/R7:
Front: 225/40/17
Rear: 255/35/18
Toyo R888
Front: 215/45/17
Rear: 255/35/18
Anyone thought or tried this setup. 15x7 in the front and 17x9 in the rear?
It seems to open up a wide range of DOT-R tire choices, for example:
Front: 225/50/15 (on a 15x7 e+35 or e+40 Team Dynamics Pro Race 1.2)
Rear: 245/40/17 (on a 17x9 e+35 or e+40 Team Dynamics Pro Race 1.2)
From looking at my 2006 donor front hubs/brakes it looks like a 15 in front wheel will work. It will be a tight fit with the 4 pot calipers but looks workable. It opens up the following tire choices, maybe more I have not found yet.
BFGoodrich g-Force R1
BFGoodrich g-Force R1S
Hoosier A7/R7
Kumho Ecsta V710
Toyo Proxes R888
Maxxis Victra RC-1
Thoughts?
