London Cobra Show
Thread: Tips on Installing Panhard bar frame
    Oct 2014
    Sachse, Texas
    I have bolted the shocks to the frame and rear end, the control arms to the rear end and frame, the upper link to the rear end and frame.
    How do I install the panhard bar frame…..the rear end is interfering with its placement.
    When I try to lift the rear end up to get the panhard bar frame under it it just raises the entire car.
    ANy tips are welcomed. Thanks in advance!
    Norton, MA USA earth
    I install the frame first. Then the lower control arms to the car. Next raise and install the rear and connect the lower control arms. Since you have it all installed, just disconnect the shocks from the rear and then raise it.
    Oct 2014
    Sachse, Texas
    Thanks Mike. I figured that was the best way as well. Once installed did it touch the panhard bar or frame at full droop?
    Senior Member Barrel's Avatar
    Aug 2011
    Mornington, Victoria, Australia
    I modified my frame but most builders don't find it necessary.
    Yes. It will touch at full droop.
    Oct 2014
    Sachse, Texas
    Quote Originally Posted by Barrel View Post
    Hi Barrel,
    Looks like FF starting doing this as well as mine came modified.
    I have a kit from late 2012. How did FF modify the 3 link panhard bar? I remember noticing this issue when first installing the rear end in my car. I was not on the forum back then. This has bothered me. I have quite a bit of equipment, mill, welders etc. so I could make a modification if required.
