Page 5 of 5 FirstFirst ... 345
Results 161 to 196 of 196
Thread: 818R #001 Build Thread
  1. #161
  2. #162
    Senior Member Tamra's Avatar
    Apr 2014
    Shelton, CT
    Nice!
    Tamra
    First autocross 3/29/15
  3. #163
    Edmonton, Alberta
    Very nice! And what a sweet track!
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
  4. #164
    818 Junkie... bstuke's Avatar
    Atlanta, GA
    I participated in a Skidpad Challenge sponsored by Grassroots Motorsports and Traqmate. The event was at the 2015 The Mitty at Road Atlanta.
    If you think that an 818 has questionable handling, think again. I still need a complete 4 wheel alignment after lots of changes, but still kicked everyone's butt by a half a G. With the lone exception of an 8 year old in a Quarter Midget. He was a ringer...
    I beat 2 Exocets, one a turbo Miata, and the other an LS7, along with 20-30 other vehicles ranging from an NSX to a dune buggy specifically prepared for the skidpad(?)
    818R For Sale!
    818R Sale Thread
    PADI Master Scuba Diver Trainer, PADI TecRec Gas Blender Instructor, Operations Manager - DNS Diving, Grand Cayman
  5. #165
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Congrats! I knew you were going to do well. Awesome 1.54G, was that based on time around the circle?
  6. #166
    Atlanta, GA
    Traqmate GPS data acquisition...
    818R For Sale!
    818R Sale Thread
  7. #167
    Administrator
    Enterprise Alabama
    Did you win the Traqmate?
  8. #168
    Atlanta, GA
    Nope. Didn't even get a trophy or a gift certificate. They may have missed getting one for the modified class. Marjorie did give me a t shirt though. They are nice peeps...
    818R For Sale!
    818R Sale Thread
  9. #169
    Atlanta, GA
    Mason walked off with the championship trophy, a GoPro AND a Traqmate! He is a really nice kid.
    818R For Sale!
    818R Sale Thread
  10. #170
    Atlanta, GA
    818R For Sale!
    818R Sale Thread
  11. #171
    south-central CT
    More importantly, did you experience any oil pressure loss or puking of oil during that constant turning? I forget your setup in that regard.
    Nice going.
  12. #172
    Atlanta, GA
    Killer B, worked fine. Boiled a little but need to burp the coolant system again.
    818R For Sale!
    818R Sale Thread
  13. #173
    south-central CT
    What I'm asking is that you be specific about what has been done to the motor to control oil surge and vent the motor. Info on your engine in the thread is hard for me to find. You have a drive by wire throttle-body so I'm assuming it is an older motor. Wayne built the motor, as I understand it. Has a KB oil pan. What else?
    The reason I'm so curious is I just returned from Watkins Glen where a buddy was having a nightmare of a time keeping oil in his engine. Has KB oil pan.
    We hooked up two Moroso catch cans and that wasn't enough for a session. Finally hooked it up to drain it back into the motor and vented the catch can.
    How did you manage to not have any issues with those constant high G's?
  14. #174
    Atlanta, GA
    Lets see:
    Stock ej255
    tomei extreme pipe and up pipe
    coolant delete and perrin oil cooler kit
    MS3Pro
    Killer B kit pan tray and pickup.
    throttle is wired.
    I have zero oiling issues. I did determine that it seems the tstat keeps oil in the cooler and lines and I overfilled the engine when I installed the Killer B. Once I figured that out everything was fine. I do need to get a real gauge on the motor but the switch is wired to the ecu and has not shut off.
    818R For Sale!
    818R Sale Thread
  15. #175
    Atlanta, GA
    Do you have a blowby issue somewhere?
    818R For Sale!
    818R Sale Thread
  16. #176
    south-central CT
    Quote Originally Posted by bstuke View Post
    I don't with my engine. I run the head breather hoses to a JEGS can and let it drain back into the engine. The other vents T together and tie into the top center case vent.
    My friend is the one with the car that may have serious blowby. It is well known that oil can fill a boxer engine head and case pressure (blowby) push it out through the head vents. I'm just surprised that you are not having issues at high G's and I still don't understand how your engine is vented.
    According to Chris of Killer B, they have a new product, an oil control valve for racecars, specifically boxer engine cars, able sustain +1.5Gs consistently. It has been discussed at length on this NASIOC thread. The next step would be dry sump.
  17. #177
    Atlanta, GA
    I have to admit I am totally clueless to this issue! I would have to refer to Wayne. Can you post any pictures of the hoses and what vents they connect to and I will replicate the photos with my setup?
    818R For Sale!
    818R Sale Thread
  18. #178
    Atlanta, GA
    Here are some shots of mine. I am going to assume stock.
    818R For Sale!
    818R Sale Thread
  19. #179
    south-central CT
    Looks bone stock to me but, I am not an early (GD) Subie guy. What I am not seeing in your photos is the CAI and turbo inlet hose area.
    Is the turbo inlet hose like this? If all this plumbing is stock then I have to question why oil is not getting into the intake.
    When we raise our boost into the 16+ PSI range, where premium, 93 octane fuel is mandatory, then you run the risk of oil getting into the intake during hard cornering and diluting the octane. Blowby increases as boost goes up. This octane dilution then leads to detonation and stock piston ring-lands break rather easily. It happened to me with my rather stock '08 STi. I knew it was an issue so I added a catch-can. My Moroso catch can quickly filled up and then started dumping it into the inlet. Sudden smoke, from burning oil, is the first indicator.
    How you don't have this occurring under high G's is a mystery to me. The KB stuff can help a lot, but it can only do so much during sustained G's.
  20. #180
    Atlanta, GA
    Lucky?
    Pretty sure all of that is stock. Running VP C16 120 Octane..
    818R For Sale!
    818R Sale Thread
  21. #181
    south-central CT
    Well, I've warned you. Can't tell you how many hundreds, nay thousands of people who have busted ring lands from injesting oil into the intake. Besides mine, I witnessed one go ka-boom from it. Intermittent oil in the intake may not cause enough detonation to break pistons because of your high octane. Watch for oil consumption and smoke.
  22. #182
    Atlanta, GA
    How does oil get in the intake?
    818R For Sale!
    818R Sale Thread
  23. #183
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Through the PCV system. Can do either an AOS or catch can. AOS is a little more elaborate but maintenance free. For your purposes, a catch can would probably be the best option. I'm not 100% certain that the catch cans do as good a job as a top of the line (heated) AOS at removing all the oil vapor though. I can show you my AOS if you like.
    Hey Bob, can you please post a pic showing how your 295 rear wheels and tires fit?
  24. #184
    Bowling Green, KY
    Bob, I have put off a Drysump for now and installed a Crawford AOS and the Killer Bee Oil Control Valve. Haven't run it yet but after research others have had good results.
  25. #185
    Atlanta, GA
    It's in the trailer...
    So I have the offset trailing arm. You have to mount it for clearance on the inside of both mount points, then shim the outer part. I got away with about an 1/8 inch spacer so it had good room to rotate if needed.
    The wheel I used is an Enkei Kojin 18X9.5 +45 5x100. I have ARP studs, and had to use 2 10mm spacers to get it back out off the trailing arm, but still under the wheel well. The tire is actually a 285/30ZR18 Hoosier A6.
    818R For Sale!
    818R Sale Thread
  26. #186
    Hindsight's Avatar
    Atlanta
    Thanks Bob. I'll paste in the Tire & Wheel thread as well.
  27. #187
    Exeter R.I
    I have the Perrin aos set up for race with no pcv. It is considered the newer setup in the community, but I have been doing this for a long time. The Crawford Aos is the other proven Aos method with no pcv. I auto crossed and tracked my Wrx with this method. I can send you a diagram of my setup.
  28. #188
    Bowling Green, KY
    Bob, there are a few photos of installed AOS systems on a few different built threads, here is a photo of mine.AOS and OCV 2.JPGAOS and OCV.JPG
    These shots are before I had the water lines run.
    As Metalmaker has pointed out this system eliminates the PCV valve.
  29. #189
    Atlanta, GA
    In case anyone is interested. No I am not buying an NP01! We are simply working towards heading out to the islands.
    http://thefactoryfiveforum.com/showt...R-001-For-Sale
    818R For Sale!
    818R Sale Thread
  30. #190
    Apr 2014
    Shelton, CT
    awe, just when I was hoping we could meet up with our 818's at an event next season
    Tamra
  31. #191
    Atlanta, GA
    Come to Dixie! I should still have it then.
    818R For Sale!
    818R Sale Thread
  32. #192
    Bowling Green, KY
    Good luck on your Sale Bill.
  33. #193
    Atlanta, GA
    Bill? who is Bill? Thanks Mitch. If you ever tear away from that Motorsports Park, come see us in Grand Cayman. Bob
    818R For Sale!
    818R Sale Thread
  34. #194
    Puyallup, WA
    I think he ment Bill of Sale as in it'll sell fast.
  35. #195
    Bowling Green, KY
    WIll do.
  36. #196
    Kirkland, WA
    I spent time with an NP01 a the 25hr Thunderhill. no thanks, not for that price, and some serious design issues with the transaxles. Good luck with the sale, I'm sure you won't have any problems selling and enjoy GC.
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
