Page 7 of 7 FirstFirst ... 567
Results 241 to 251 of 251
Thread: Jaime's Western New York Build
  1. #241
    Leesburg, VA
    Quote Originally Posted by Jaime View Post
    This stuff?
    Attachment 38108
    Right, how much should I get? Is this the stuff?
    http://www.amazon.com/TechFlex-Woven.../dp/B00C1O7SO4
  2. #242
    Sorry, the link didn't work in my previous post, I fixed it. There are two variants, the red-logo F6 and a green-logo, also called F6, version. The green stuff is a bit more expensive and has higher heat tolerance, I used that for wires near the engine. I've gone through about 20 feet of 1/2 inch and 20 feet of 1/4 inch so far. I stripped my entire harness, so I have a lot more bare wire than some.
  3. #243
    Leesburg, VA
    Thanks a lot, I'll check those out. I also stripped my entire harness.
  4. #244
    The third brake light looked a bit thin to me after I got it in, so I did it again with 3/8 acrylic...
    Here's how it looks installed:
    I still have to clean up the opening a bit and wait for the new LED strip to come in.
  5. #245
    QC, Canada
    This is the bracket that will hold the strip on?
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
  6. #246
    LED strip will be siliconed to the inside of the lens. The lens bolts up to the bracket, which is glued to the body.
  7. #247
    My car "looks finished", but I still have a lot of detail work to do. Here is where it's at right now:
  8. #248
    I got these parts, guess what I'm making.
  9. #249
    Jaime,
    Your Car is looking great.
    I suspect you are making some kind of hood hinge.
  10. #250
    Bingo. I'm go to try to make one of these:
  11. #251
    Jun 2017
    Jaime, Just bumpin the thread, wondering how things are going. I myself have just bought a donor car, I was kinda wondering if you still had the car. And wouldn't mind meeting up. I wanted to see one in person, and before I get too into this build want to make sure this is the ave. I want to go down.... I also live int the WNY area. Cheektowaga to be exact.
