Results 1 to 3 of 3
Thread: Cooling fan problem
    Sep 2014
    Cooling fan problem
    just got to the motor started point and a problem came up with the cooling fan. As soon as I connect the battery the fan comes on and when I turn the key to run it goes off. I am using the RF harness with a thermal switch in the thermostat housing. I assume the switch provides a ground for the fan relay so I disconnected the switch, fan still runs.
    Any ideas? This has me puzzled
    Tom
    Btw 302 carbed if that helps
    Senior Member HCP 65 COUPE's Avatar
    NORTH CENTRAL CT
    Check the relay is wired correctly, I had a relay that was mis-wired on the RF harness mine happened to be the horn.
    Sep 2014
    I appreciate the help. Got the meter out and figured out I had the coil/tach wire and the temp switch wire swapped. Alls good. Thanks again
    Tom
