Now imagine that sitting nice and close to a fuel tank and brake lines.
Zero Decibel Motorsports
Check out my new website!
Put some temporary wiring in and tried to start it last night. Had a small grounding issue at first but second try it worked great! It sounds fantastic and runs nicely off of idle. Doesn't idle nicely, but it's missing the front O2 right now. We had the fire extinguisher on retainer anyway. So excited!
https://vimeo.com/121585518?utm_sour...B8NzcwMQ%3D%3D
Congrats! Sounds strong!
Congrats on the first start!
whoo hoo congrats!
Tamra
First autocross 3/29/15
Thanks everyone! It was a pretty exciting moment. Now I'll be in Sweden for work for around a week, so progress will slow. I'm not -too- upset
You are a lucky builder to be there!
Tracked May 27/July 26, 2017
Build Completed Winter 2021
https://vimeo.com/122595258
She runs now! Found a vacuum leak and now I think we're good to go. Tapping in the fitting for coolant this weekend and driving it down the driveway! So excited
Edit: Sorry for the swinging camera; it's awful. I threw the GoPro on the hook and excitedly ran over to the car. Too excited to remember to stop it from swinging, it seems!
Hey Frank, you also might want to consider a heatshield/insulation between your cooling pipes. With the hot and cold pipes so close, it will reduce efficiency by thermally 'short-circuiting' (It's basically a counter-flow heat exchanger... the returning coolant will get heated by the exiting hot).
818's seem to need all the thermal management they can get, especially for an R!
Man that's great it runs! Close to a real drive, now!
No, you might get a bit of extra cooling from a bare hot pipe (how much airflow is there when the body is on anyway?), but if your radiator's working and properly sized, the cold pipe should not be that much above ambient air temp (not enough that the pipe will help). There is a very big Delta-T between the two two pipes, and you do NOT want the hot pipe to dissipate heat to the cold pipe; any heat transfer reduces the efficiency of the cooling system. Wrap the cold pipe, or just put a flat shield/insulator between them, but as is, I have concern about the returning coolant being too warm.
First drive! Well, kind of second drive but whatever! It's quick, and just a little throttle sends it all over the road. Nice exhaust note, too! Time to set up an appointment at the tuner....
https://vimeo.com/122920207
That's great. Get a body on it and some aero to handle all that power.
"Scotty, give me all the TRACTION she's got!" Pictures of what I drive till 818R is finished
Track Car Journal on IWSTI (with build info)
Congrats on the first drive!
Congrats and good luck and the tuner! What are you hoping for?
Tamra
Thanks! I'm hoping for smooth power delivery. I know this motor made "big power" when it was in the WRX it came out of (at one point Mikey had tuned it, actually), but that's not at all what I want for the 818. I want smoother torque than my WRX, that's for sure!
Your full spool by 3,500 rpm is more like what I'd like to see, I think.
Over 60* and sunny in upstate NY? Way too nice of a day to work inside!
Prepping the trailer, truck, and car with hopes that I'll be able to go tune and align suspension soon. What an exciting time! I believe the first event I'll be able to make is an autox at Cherry Valley with SCCA on May 30th. It's a day/night event, so probably 818 by day and either the WRX or a friend's Mk VII GTI by night.
PHEW! Back from 2.5 weeks in Europe. Incredible trip, even drove on the Autobahn (slowly...there was traffic).
Landed late Saturday night, caught up on some sleep, and spent all day yesterday doing 'Merican things. Grilled, had some beers, and of course trailered the 818 around! Stress test on the truck. We found some nice hills, did some stops, etc.
Truck LOVED it. Though, I am putting new brakes on it and new shocks/slightly bigger leafs. Now if only the car would leak a touch less oil....
Ugh- truck ate a serpentine belt today. Had to limp her home on 2 belt ribs. Guess this weekend is all about diagnosing that issue and general car prep. Tuning is in Lake Placid at Moon Performance next Saturday and the following Saturday is my first autox! Pretty excited.
In the mean time, I made a mount for the intercooler:
How did everyone else mount these? I'm curious.
On the drivers side I'm using the stock IC bracket. On the passenger I couldn't use the stock since, like you, I have an STI sized intercooler. I welded a tab to the crossbar, since I have nearly solid engine mounts I'm not as concerned about movement like Bob warns -but I need to verify this with testing.
Mike, I agree with what you were thinking. My engine mounts are very solid and the engine doesn't seem to move a ton. I was hoping the rubber grommit would be sufficient for absorbing the movement relative to frame. That said, mounting to the engine seems like a cleaner solution overall.
We used the Group N mounts and there is still quite a lot of movement.
Tamra
Here's another thought on the intercooler mounting issue. I was at the track yesterday and a Subie guy was tracking his STi for the first time. He did a lot of things right under the hood, but he did not wrap his turbo or downpipe at all. Not even a shielding plate over the turbo. He was cooking his IC.
It seems we have the luxury of added space to play within. Because there's little or no airflow at times why not offset the intercooler where it does not get heatsoaked by the turbo? Why not tilt it more for better air flow?
What about reversing the intake and having the intercooler farther forward? I'm asking questions because I haven't mocked up any of this yet and don't know whether I'm talking out my rear or not.
On engine movement: If you have tubing long enough (how long is long enough?) then you could hard-mount the IC. Radiators are hard-mounted. My FMIC is hard-mounted
What Scargo Said! Once the hard-top becomes a reality I will be revisiting the issue of IC mounting. I plan to reposition (vertically) & duct it to take advantage of airflow & add room to keep it away from the turbo.
I actually had to trim down my IC to TB hose (because of fitment issues with the V5 intake manifold), so I have less hose-give in that area, but between having one side of the IC mounted to the engine & the other to the frame with the cushioned IC mounts; I hope it will be OK.
Seems Jim Pampas is building an 818R but is off-grid as far as the 818 forum it seems. Here's a video of their startup. The point is to bring to everyone's attention the intercooler mounting they are using (high and over the tranny longitudinally). Hopefully they'll get the turbo and exhaust wrapped.
Thanks- Chad
Thanks- Chad
Good luck!
Tamra
Ps just clicked to post 1 to refresh my memory of your build. Nice job on the highlights links!
Tamra
I have To agree, the highlights links are a great idea!
