Results 1 to 40 of 41
Thread: RoRi's Custom Parts - Steering Column Spacers
    rori's Avatar
    Tulsa, OK
    These steering column spacers allow you to collapse the steering column to position the steering wheel closer to the dash and eliminate the gap left by using the factory mounting points. The spacer allows for up to 50mm(2") of adjustment. You can get up to 1.25" by simply pressing the steering shaft into the outer sleeve; don't press it farther than this by going beyond the thick part of the shaft. You can gain more by collapsing the outer sleeves together and then you can press the steering shaft in farther, again not going past the thick part of the shaft. Access to a large press will make this easy, you can also use a floor jack under something really heavy (i.e.: semi-trailer), or some users have mentioned simply using a hammer to tap everything together.
    $50 plus $5.80 priority shipping in the USA.
    Steering column spacer:
    Bolted to the steering column:
    Closes the gap between the dash:
    This is what it looks like in the stock location:
    With the bracket:
    FSM diagram showing the collapsable steering column, you'll be pressing 3 into 2 and then pressing the shaft into the whole assembly:
    Side by side comparison; compressed steering column vs. stock:
    RoRi's Custom Parts - Radiator Spacers
    Apr 2014
    This is awesome. The "stock" gap looks like butt. Need this
    Anyone has got Rori's contact info other than a PM?
    rori's Avatar
    Tulsa, OK
    Sorry for the late reply Frank. I'm enjoying some vacation time in FL. I'll be taking orders again when I get back.
    Just so people know, I am 5'6'' and I need to collapse the column by 0.5 to 1''. The other possibility is I fix my seat very high (4 to 6''). The sw is too close to me to be comfortable and if I push the seat back, we know what happens, it hit the tank fw. I think this column spacer could be very useful for a lot of people.
    Robert, we can you any bolts that fit in the round holes, right?
    rori's Avatar
    Tulsa, OK
    Yes, I think I used the nut and bolt that FFR provided for the steering column. A thin walled or 1/4" drive socket should fit nicely.
    Yes the 2 bolts/nuts that came with the FFR kit + 2 more. 2 bolts to attach the spacer on the column and 2 more to attach the spacer on the FFR column bracket. I'll check that out tomorrow.
    Robert, might want to think about revisiting the spacer. It's not long enough. The 2" of adjustment is just too short for me, I need 2-1/4" to 2-3/8" and there was more possible to collapse on the column. I will have to enlarge the FFR bracket holes, but just a thought for future versions.
    Feb 2013
    Bowling Green OHIO
    just an fyi for others.... i drilled another set of holes 1/2" towards the headlights, ffr bolts still fit good with washers. this will give you a total of 2.5" of adjustment or get the wheel 2.5" closer to the dash. hope its not to close to the dash since i havent installed that yet but i had no problem getting the steering column to press down that far. used a bottle jack in my basement and sat the wheel on an end table and pressed against an overhead I beam. used a schedule 40 pipe to press outer column then did the shaft. shaft actually fell all the way in thru the bushing/bearing but was able to use coat hanger hooks to pull bushing out then grabbed the shaft with pliers and lifted it back up/out. shaft moved very easily on mine so it made reassy easy.
    rori's Avatar
    Tulsa, OK
    Did your chassis' have two sets of mounting holes for the column? My chassis had two sets about a half inch apart. It sounds like FFR has done away with the second forward set of holes.
    Feb 2013
    Bowling Green OHIO
    Quote Originally Posted by rori View Post
    yes mine did, chasis #115 i added a third set towards the front
    2 sets for me too, but no place to drill a third one. I have to check again on that.
    rori's Avatar
    Tulsa, OK
    I only have 2 left. I will probably not be ordering anymore due to slow sales. PM now to get one of the last 2.
    PM sent
    rori's Avatar
    Tulsa, OK
    I've had a few requests recently for brackets so I went ahead and placed an order for 10 more. They are due in at the end of January. PM me if you want to get in on the order.
    1. ben1272-shipped
    2. vrumpsh-shipped
    3. gwarden-shipped
    4. Speedy G-shipped
    5. FFR-ADV-shipped
    6. Will D-shipped
    7. NISMO_RB25-shipped
    8. SnyderJD-deposit paid
    9. Blwalker105-shipped
    10. Ethan818-shipped
    May 2013
    Colombia
    Hey I'm in! Awesome!
    Speedy G
    Senior Member FFR-ADV's Avatar
    NH
    Hi RoRi,
    Please count me in on the steering column spacers. Thanks!
    May 2013
    Colombia
    Bump!
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    I love mine. Got the steering wheel out of my face and exactly where I want it.
    Apr 2015
    Andover, MA
    From an aesthetic perspective, I think the wheel looks better closer to the dash. From a functional perspective, does it put to wheel too close to the pedals? I am 5"11" with 31" inseam and don't have seats in my 818 to test sit in yet. I have asked Rori to reserve me one of the spacers.....do you all think it will be a good fit for me? What are some of your heights/inseams?
    Hindsight's Avatar
    Atlanta
    It's adjustable. You can collapse the column as little as you want. I'm 6' 30" inseam. I'd like the steering wheel to be a bit lower (even with the tilt all the way down) but the ability to adjust forward and back was critical.
    rori's Avatar
    Tulsa, OK
    Steering Column Spacers arrived today. There are 4 unspoken for. Let me know if you are interested.
    Senior Member Blwalker105's Avatar
    Hi Rori, Count me in.
    Quote Originally Posted by Blwalker105 View Post
    Rori, count me in for one as well.
    Apr 2015
    Andover, MA
    Received mine. Thanks! It is gloss black now and will be installed by the weekend I hope.
    May 2013
    Colombia
    Hi Rori, you still got these? I'm still interested in 1. I've off the board for a while.
    Speedy G
    I'll take one if you still got one, pm me! Thx.
    I'm in for one should you end up making more.
    Mechie3's Avatar
    Rori sold his car. Not sure he'll be making more.
    Zero Decibel Motorsports
    Hindsight's Avatar
    Atlanta
    I guess that means you'll have to pick up to torch eh??? ;-)
    Senior Member AZPete's Avatar
    Torch? I made one from a steel plate by drilling 4 holes in it.
    I guess I'll have to dust off my man card and make my own AZPete style.
    i see what you did there.
    Saint Charles IL
    Arg! Now that I see this... I REALLY want one. :-( Sounds like steel plate will be my solution as well, unless someone wants to CNC fab some aluminum ones yet again! ;-)
    Leesburg, VA
    Quote Originally Posted by axelthrasher View Post
    Just 2 weeks too late...
    http://thefactoryfiveforum.com/showt...Spacer-Adapter
    Clovis, Ca
    I just 3D printed mine. Worked great and still is for the new owner.
    Thanks- Chad
    Saint Charles IL
    For those interested: you don't need a bracket to reduce the gap between the OEM Subaru column cover and the FFR dashboard. I was able to reduce the gap by drilling some holes in the column mount further towards the dashboard. You also need to collapse the steering rack, which is easy to do by lightly tapping with a hammer. Just pull the rack out, remove the steering wheel and tap the end that goes into the steering joint near the steering rack a bit. Draw a line on this shaft with a marker - only about 1/2-1" needs to be collapsed.
    Jun 2017
    Alex,
    What seats are those.. about to start my build and looking for seats..
    Thanks!!
    Saint Charles IL
    Quote Originally Posted by kcarlasc View Post
    Alex,
    Thanks!!
    Cipher CPA-2001 Seats, good luck! :-)
