Likes Likes:  3
View Poll Results: What is your interest level in owning an LCD system?
Voters
19. You may not vote on this poll
  • I like what I'm seeing so far, and the price is fair. I would sign up!
    9 47.37%
  • I'm interested, but I'd like to know more about the product before committing.
    7 36.84%
  • No thanks, too expensive and the analog gauges are just fine for me.
    1 5.26%
  • Sorry, too late. I'm not removing my dash to modify the pod.
    2 10.53%
Results 1 to 23 of 23
Thread: Custom LCD Gauges - Who's Interested?
    LCD Gauges's Avatar
    Toronto, Ontario
    I’ve signed up as a vendor, and as many of you have expressed interest in my LCD
    gauges
    Happy 2025! I write this at my first thread of the year, and return forum sponsor!
    As I read back on the previous posts from years ago, I'm amazed at how far we've come from the very first
    design, to the current level of our product. Everything has evolved and improved from hardware, programming,
    and graphic quality.
    We've hired two part-time assemblers, and a programmer who is helping us with LINUX based systems, and a host
    of other code enhancements. Our kits are now built with 6-20 volt power supplies which reduces circuitry for crank
    support from the previous 9 volt supplies.
    Our 200 Series Interface Modules now incorporate the same automotive grade locking connector as the 100 Series
    modules.
    Enjoy our latest promo video, and graphic skins.
    Our website is always updating with user friendly interfaces, and a new Customer Install page:
    https://lcddash.com/media/
    I will use this thread as the main source for updates, and link all forums here.
    Get in touch via Private Message if you need anything, or have questions!
    Thank you,
    Tino
    New Console Layouts (10, and 12 inch touch screens):
    Attachment 208341Attachment 208342
    Our webiste:
    www.LCDdash.com
    LCD Gauges's Avatar
    Toronto, Ontario
    For those that would like more information, please send me a Private Message or post your question here. I'm sure there are several bits of info that
    I forgot to mention in my first post!
    Nice design! Driving an S6 makes those gauges very familiar indeed!
    Do you plan to include things like an odometer?
    The pic shows the tach display in "cold engine" mode. Will you animate the red "LEDs" along the edge of the tach as the engine warms up like the real car?
    LCD Gauges's Avatar
    Toronto, Ontario
    Thank you, and good questions.
    Quote Originally Posted by Boostaddiction View Post
    Yes, it will be stored in a non volatile memory within the processor.
    At the moment, the "redline" is static. In updated photos, the limit is set to the estimated upper shift limit for my engine (~6500 RPM). It would be
    easy to animate the "LEDs" as temperature increases to operating values (it would be similar code to the temperature LEDs).
    Senior Member The Stig's Avatar
    Charlotte, NC
    Hi Tino,
    I may have missed it, but would this package be compatible with the InfinityBox (ISIS) wiring system?
    The Stig
    GTM #0081
    LCD Gauges's Avatar
    Toronto, Ontario
    Mike,
    Good call on the InfinityBox. I didn't consider any interface with other systems in my concept, but there is definitely methods of doing so.
    I'm interpreting "compatible" a few different ways, so let me clarify:
    - The LCD gauges can be installed in a car with the ISIS system as it operates independently.
    - Can the LCD system receive inputs, and updates from the ISIS? I would need to know specifics on voltage, and signal type, as well as function.
    The processor can accept a wide range of information, so it can be programmed to accept an output from the ISIS system. Perhaps I should have
    an InfinityBox user as a Beta tester if there is such a need to communicate between boxes.
    - Can the LCD system output information to the ISIS? I would have to research the requirements for the data types, and voltages of the system.
    I'm aware that the InfinityBox is able to control doors, engine start/stop, smart phone remote etc. which the Advanced LCD kit will do as well.
    The User can select which system they choose for operating these functions, or the LCD gauges can easily be programmed to work in unison.
    This will be part of my homework when the Advanced Kit is ready to debut.
    FYI: For those wondering, the Basic LCD system can be expanded for engine start/stop, smart phone remote, door/hatch/hood release, etc.
    LCD Gauges's Avatar
    Toronto, Ontario
    After speaking with Ron (my Fiber, and Carbon go-to guy), he has figured out a way to install the screen without modifying the pod!
    This means a much faster proto-type, and beta test date. All that is needed will be a new carbon fibre face for the trim. Thank you
    again Ron for the idea. Those of you that already have completed cars, and wish to get into this system will have a much easier time.
    LCD Gauges's Avatar
    Toronto, Ontario
    I'm updating the progress as time allows. This evening a template was made to get measurements for a temporary poly/Lexan faceplate.
    While the bugs get worked out, I'd like to try my hand at a carbon fibre piece, and possibly an aluminum trim as well.
    For those that have new GTM kits and have not cut up their carbon fibre faceplate, you're in luck. The mounting system that I have in mind
    will work well with the stock piece. Details coming soon.
    I'd like to get two Beta testers within the next few weeks. Someone that is fairly good with connecting wires in their car, and can be
    reached by phone if needed to discuss possible snags. If you would like to become a Beta tester, send me a Private Message with your
    name, and email.
    I'd like to have a video uploaded within the next few days to detail the features of the system. Enjoy the photos
    P.S. The GTM photo in this image will be replaced when the Beta kits ship.
    LCD Gauges's Avatar
    Toronto, Ontario
    A quick update for those following along:
    I've made a decent poly template that will serve for testing purposes. It just needs some clean-up around the edge, but otherwise fits the dash pod perfectly.
    There is a 1/4" gasket material between the screen and trim plate. My next step is to find suitable hardware to mount the tablet, and we're off to the races.
    I'm working on the demo video this weekend, and will upload everything as soon as possible. The video will show all features, and functions of the system.
    LCD Gauges's Avatar
    Toronto, Ontario
    As promised, I have a demo video to share with everyone. I’m a little disappointed about the clarity due to my camera being out of focus for the entire presentation. My voice is also a bit low overall, however you can still hear everything. I’d like to redo this video using video capture software so that you can see everything in high
    definition. In any case, this version should answer most of the questions for those who were wondering about features, and functions.
    I am including the screen shots since the video is blurry, and if anyone would like the executable file, I will email the information so you can play it on your home computer to get a sense of the details and resolution.
    The total viewing dimensions are 9 inch width x 5 inche height (8 7/8 x 4 15/16”)
    Gauge diameters are 3 7/8 inches
    Installation will be quite simple. If you can plug in a USB cable, and connect wires to some screw terminals, it will be a snap. As mentioned, I'm working on
    a manual, and video of the connections. All wires will be labelled, and colour coded when possible.
    I forgot to mention in the video that the data logging feature will track KMs/Miles driven each day, and the amount of fuel used (based on the sender voltage, and
    data figures you enter from MPG testing of your personal car).
    Charlotte, NC
    That is amazing Tino! It appears to have everything that you could want in order keep track of the car's systems.
    The Stig
    GTM #0081
    LCD Gauges's Avatar
    Toronto, Ontario
    Thanks Mike! I'm trying to make this kit as complete as possible, and versatile.
    Who would have thought I'd end up developing a product when building this car?
    I'm working quickly to get the baseline tests uploaded by the end of the week,
    and then roll out some Beta units once everything checks out.
    Charlotte, NC
    Quote Originally Posted by Lukn4trbl View Post
    The really cool thing is that it is not limited to the GTM.
    I could see using this in any custom build. I have a 37 ford project that will take place a little later on, and this would work beautifully in the confined dash space of that car. Any retro-mod to Corvettes, Mustangs, classic Pick-up Trucks, etc., would benefit from something like this.
    One of the coolest things about modern Jet cockpits, is the EFIS systems.(Electronic Flight Instrument System). Everything is dark glass panels until you light them up, then you see the crisp imaging of the instruments on the screens. The good thing is that when using a system like this in a car, the driver isn't screwed if the computer crashes. (Jets have redundant systems, but you see what I mean)...
    I'd suggest that you should:
    - Apply for a patent QUICK!
    - Test the crap out of it in your GTM, real world driving.
    - Determine your cost to produce & ship.
    - Determine realistic lead times.
    - Then advertise it in magazines such as Street Rodder & the Good Guys Gazette.
    - Post a video showing functionality on Car-Centric web-sites,
    - and from that point on, be ready to produce!
    Nice product.
    The Stig
    GTM #0081
    LCD Gauges's Avatar
    Toronto, Ontario
    Awesome Mike! You do know I work in Aviation, and LOVE avionics?
    Thanks for the positive comments, it is motivating!
    San Diego
    I don't want to be negative, but you do realize that there are quite a few programmable dashes out there already, right? The latest one from Motec is currently my favorite. Although I will hand it to you that your packaging is pretty nice, and digital analog gauges are pretty limited on the other options I have seen. The Motec is pretty expensive, but the Racepak, and AIM units are nice also, and much cheaper. As I have posted previously, I am also a fan of the SPA consoles, especially for street cars.
    http://spatechnique.com/store/itemList.cfm?catID=6
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
    LCD Gauges's Avatar
    Toronto, Ontario
    Hey Mike, no negativity taken!
    I know there are a few out there, but I believe this design out performs what's available, and for a 1/3 of the price. I'm not sure what
    you're getting for prices, but MoTec and Autometer are selling for $3100-$4000 USD + tax depending on the system. The SPA are listing
    for $1400 USD + taxes.
    My kit has a larger display, way more options, personalized interface, data logging, gps, accelerometer,and also interactive. Not to mention it is designed
    with FFR platforms in mind (can be custom tailored to most kits).
    I'm also working to integrate Traction control, ABS, and a host of other add-ons which you can't get with the other brands (smart phone remote,
    alarm system, twilight sentinel, etc.).
    It's essentially an expandable controller that logs, monitors, and controls vehicle functions. I'll have to clarify that information as it may seem
    vague at the moment.
    The initial systems will perform as shown in the video, but can be expanded to replicate functions of OEM electronics.
    Coincidentally, I'm working on a matrix that compares these products and their features/performance.
    LCD Gauges's Avatar
    Toronto, Ontario
    Here is the higher definition video; much better than recording a monitor with a camera, but still not the true resolution.
    Be sure to expand the video for full screen view to get the best clarity.
    LCD Gauges's Avatar
    Toronto, Ontario
    YouTube couldn't process the last file because it was too high in resolution. Here's another attempt at better clarity of the demo. This file had to be converted to MPG from AVI so you will notice some compression loss. Be sure that your YouTube settings are High Def (720) for best viewing quality.
    I'm about a week behind in electrical wiring of the GTM, so I'm targeting next week for the in-car test/demo. I've had some 818 guys message me for testing,
    but still looking for GTM owners for beta testing.
    Thanks!
    Senior Member sk7500's Avatar
    Very nice!!!
    LCD Gauges's Avatar
    Toronto, Ontario
    Thank you Steve! This afternoon I was able to get some more testing in the GTM, and I'm happy to say things are ready to move forward.
    I'll be starting a new thread with datasheets, specs, and promo later this week. I'm still looking for two beta testers who will receive the kit
    at a discounted price.
    Thank you to everyone who helped out with the poll, and asked questions. Stay tuned for the new thread, and information.
    LCD Gauges's Avatar
    Toronto, Ontario
    Happy 2025! I’ve signed up as a vendor a second time, and as many of you have expressed interest in the LCD gauges!
    Please use the following thread for the latest updates:
    https://thefactoryfiveforum.com/show...410#post571410
    Our webiste can be found at:
    www.LCDdash.com
    glassReflect.pngSpaceSkin.jpgwoodgrain.jpg55TruckDemo.png600LT.pngC8glow.pngGTMpromo.pngchironTease.png
  22. Likes maclonchas liked this post
  23. #22
    Feb 2019
    Houston, TX
    Quote Originally Posted by LCD Gauges View Post
    www.LCDdash.com
    I think there might be an issue with the link to the other forum post, it tells me prohibited.
    But this is back on my radar since I’m moving on to an aftermarket ECU. Glad to see you are still selling these.
  24. Likes LCD Gauges liked this post
  25. #23
    LCD Gauges's Avatar
    Toronto, Ontario
    I made an error. The forum is only visible to vendors, so I'll have to copy the post here:
    modules.
    Thank you,
    Tino
  26. Likes beeman liked this post
