Page 1 of 5 123 ... LastLast
Results 1 to 40 of 170
Thread: Group Buy: Hood Hinges
    Mechie3's Avatar
    Indianapolis
    Now Taking Deposits. See post on page 2.
    What: Group buy for hood hinges that swing the hood forward and allow you to eliminate the front hood pins.
    Cost:
    5-9 people: $205
    10-14 people: $190
    15+ people: $180
    Green = $90 deposit paid
    Blue = Full $180 paid
    1: AZPete
    2:Svanlare
    3: 65 Cobra Dude
    4: Hendow
    5: Stebru84
    6: K3LAG
    7: lifunfe
    8: bbjones121
    9: Hindsight
    10:SpeedyG
    11: 508WRX
    12: NBinSD
    13: Harley818
    14: Dougkirkbride
    15: Wleehendrick
    16: Goldwing
    17: Suttonb3
    18: ninjanick
    19: Junty
    20: Brian B 36
    21: Hawirick
    22: EODtech87
    23: DMC7492
    Coupe:
    24: Metros
    25: Flamshackle
    26: 07Fireblade
    27: Frank818
    28: FFR-ADV
    29: Red Fogo
    30: Joseph
    31: Cmicintyre
    Coupe pricing will be adjusted based upon cost of coupe specific arm.
    Buy both the trunk hinge and the hood hinge and save $20 off the total.
    What You Get:
    Two hinge bases (laser cut, bent, TIG welded)
    Two hinge arms (laser cut)
    Two hood brackets (laser cut, bent, TIG welded)
    Hood Brace (laser cut, bent)
    Rivnuts for frame mounting
    Bondable studs for hood mounting
    All stainless hardware
    Does not include gas pistons, though when those parts are available, they can be easily retrofitted to the basic hood hinge.
    Group buy will stay open for a week or two depending on volume of response. 50% deposit due at the end of group buy. Lead times on parts is roughly 2 weeks.
    Matteos install can be seen here:
    http://thefactoryfiveforum.com/showt...l=1#post202454
    Dan's install can be seen here:
    http://thefactoryfiveforum.com/showt...l=1#post202558
    Development can be seen here:
    http://thefactoryfiveforum.com/showt...l=1#post199593
    Zero Decibel Motorsports
    Check out my new website!
    Senior Member AZPete's Avatar
    Absolutely, I'm in! Will you let me know when you want money?
    Pete
    Freeport, ME
    PS, the hood hinges will fit both wide and narrow radiator frame cars, you just reverse the hood brackets
    They look AWESOME in person, as do Craig's rear hinges
    Dan
    San Jose, CA
    I'm in
    Senior Member metros's Avatar
    NoVA
    I'm in. You should update the thread title when payment is due.
    Port Charlotte, FL
    Craig,
    I am in. Let me know when to send payment and how much.
    Thx,
    Henry
    QC, Canada
    If you're sure it fits the new nose, I'm in.
    I don't see why it wouldn't?
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
    Mechie3's Avatar
    Indianapolis
    Needs new vertical arms to fit the coupe nose.
    QC, Canada
    Same price?
    I mean, even if the arms aren't designed yet for the new nose, can I (we) still benefit the 20 bucks off from group buying the rear deck lid hinges + hood hinges for new nose?
    Member Hendow's Avatar
    Sep 2014
    Having witnessed my hood moving around under the 'Quicklatches' at 220km/h, I could not possibly be more interested in a set of your hinges!!!
    Sign me up!
    Mechie3's Avatar
    Indianapolis
    Frank, $20 off is an indefinite sale not related to the group buy. The coupe arms might cost a little more as they'll need to be a big longer/bigger to clear the black area.
    Lansdale
    I'm in!
    FFR 818s #248 received 10/24/14
    first start 3/9/15 https://youtu.be/aRivN83ym-0
    first gocart 3/28/15 https://youtu.be/0Cq9LLzM_40
    first auto-x 4/12/15 https://youtu.be/4ada081tuks bloopers https://youtu.be/ZnBk0C-9uxE
    Body on auto-x Pocono pa 9/20/15 https://www.youtube.com/watch?v=chwtszG7vyg
    PA Titled and inspected 7/15/2016
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    I'm in!!
    Mechie3's Avatar
    Indianapolis
    Matteo sent me some photos last night of his install. The extra bracing around the louvers was his work, but something you might want to do to improve overall hood rigidity.
    These shots show you were it sits:
    San Diego Ca 92106
    Love the X-Ray photos.
    Feb 2014
    Ramona, CA
    Buy these hinges, its worth it.
    The X-Ray Photos...
    The pictures also show that the area in front of the radiator/heat exchanger is sealed from the area behind the radiator/heat exchanger. I put some sheet metal with bulb seal to fit against the hood. I think I took the idea from Chad. All air must go through important parts.
    Back to topic, hinges. The hinges are a requirement (IMHO). I need to open the hood(s) so often to work on stuff, and to show people. It would really suck, to fully remove the hood and find a safe place to put it, every time someone asks to see whats inside.
    I have gas shocks that are ready to install, but I have not put them in. It works so well without them. It stays open fine, and stays closed fine. I do use the two rear pins. I don't think the gas shocks would keep the hood down at high speeds.
    San Jose, CA
    BTW - I'm in for both.
    I am in for the hood hinge.
    Lifunfe
    Mechie3's Avatar
    Indianapolis
    Thanks everyone. I updated the list and updated the break points. It used to be 5-10, 11-15, 15+, it should have been 5-9, 10-14, and 15+ because my price breaks with the supplier are at 10, not 11. Makes it easier to hit cheaper numbers.
    QC, Canada
    So according to the list I'm not in yet cuz of the new nose, am I correct?
    Mechie3's Avatar
    Indianapolis
    Well, I didn't know if you actually wanted in or were just asking about the nose. Lol. If you want in to reserve a future spot with new arms +/- some amount due to difference in cost of the new design I'm fine with that.
    NoVA
    I was under the impression that these would be modifiable for the new nose. That puts me on the fence as well. I'm leaning heavily towards adding the new nose, but really need to see what it's going to cost first. If it's going to slow me down then I think I'd rather keep what I've got.
    Either way I go I will be purchasing this hinge kit for sure.
    Mechie3's Avatar
    Indianapolis
    It should be modifiable. I'm 90% sure. The thick vertical arm has the offset at the bottom which will need to get bigger so that when it opens it clears the taller lower grill of the coupe front end.
    Senior Member Flamshackle's Avatar
    Aotearoa (New Zealand)
    I am keen for this item if you are doing one for the coupe...
    __________________________________________________ _____________
    That man is no fool, who gives what he cannot keep to gain what he cannot lose
    Jan 2012
    I want in to for future arms for the new front end. Just like frank.
    Denver, CO
    Add me to list, I have been on vacation.
    QC, Canada
    I'm happy to see many of us are thinking about these hinges for the new front end.
    Jan 2012
    Now only if we could figure out what hinges FFR is using for the hardtop glass if it's going to be a swap of the stock ones then maybe mechie rear hinges would work too.
    Mechie3's Avatar
    Indianapolis
    Bump for a new week. I'll end the group buy this week and get parts on order this coming Monday.
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    I'm in!
    May 2013
    Colombia
    K, just remember I'm the one that brought the price down to 190.
    I'm in with both the trunk and the hood hinges.
    Speedy G
    Member 508wrx's Avatar
    Nov 2012
    Taunton, Ma
    I'm in Craig.
    Hood hinge only.
    "aerodynamics is for people who can't build engines" - some old dude
    "Shut up! I know what I'm doing" - some angry finn
    Mechie3's Avatar
    Indianapolis
    4 more people and it drops to $180.
    Senior Member NBinSD's Avatar
    Sep 2014
    I'm in.
    Harley818's Avatar
    Vancouver BC
    Looks awesome. I'm in Mechie!
    Let me know the details when you need payment.
    Harley
    Bought 2002 Donor Jan 2014
    First Start Jan 18, 2015
    First Drive Feb 14, 2015
    Feb 2013
    Bowling Green OHIO
    these look great, robust also. I am in for the hood hinges.
    Doug
    Mechie3's Avatar
    Indianapolis
    One more and we hit the lowest price bracket.
    Jul 2012
    Encinitas, CA
    Alright... I'm in!
    QC, Canada
    Yes sir!! Tnx to wlee!!!
    Nov 2012
    Medina, OH
    I'm in too!
    Rich
