Page 38 of 54 FirstFirst ... 28363738394048 ... LastLast
Results 1,481 to 1,520 of 2134
Thread: Plavan's 818R Build Thread
  1. #1481
    Senior Member metros's Avatar
    NoVA
    Cool pictures.
    Hope this is enough for you. I'm assuming these are all ran in series? Any downsides to having that length of oil lines? (Other than weight of course) Will it affect oil pressures?
  2. #1482
    Senior Member Flamshackle's Avatar
    Aotearoa (New Zealand)
    I'm adding my third oil cooler into the car drivers side front. It's the same size as other oil cooler on passenger side, but I moved the splash guard and cooler forward more away from wheel. I just need to go grab some bigger hose clamps for the bumper to oil cooler ducting hose.
    Next up is installing a racing thermostat (coolant) and some silicon hoses, then bleed and fill back up. I'm shooting for testing on Friday. I hope it works, then I have the NASA championships at Laguna Seca at the end of the month.
    Fair to say we are all watching and waiting to hear some good news :-) go well man can't wait to hear how the car performs.
    __________________________________________________ _____________
    That man is no fool, who gives what he cannot keep to gain what he cannot lose
  3. #1483
    Clovis, Ca
    Oil lines, oil lines everywhere!
    Thanks- Chad
  4. #1484
    What thermostat are you planning on running now? Just a std 160 or something fancier?
  5. #1485
    Clovis, Ca
    Just a 154 degree Mishimoto Racing one. I'm not expecting miracles as no one should when replacing a thermostat, but it will help the engine oil heat exchanger for a bit :/ . Better than the 172 degree one. I would not put a lower T-stat in a street car, but a race car with constant revving, and higher temps wont hurt (not stop and go).
    I also found out my primary fan #1 fuse was blown when I filled the coolant system (I hotwired the second fan to help with IC HE). That would explain the creeping coolant temps last practice, I thought it was the 105 degree ambient outside temp.... Thats fixed. I used the Airlift coolant filling vacuum tool. I'm very impressed with it. It worked awesome on a fully drained coolant system.
    I also uncapped the passenger side radiator port (and took bolt out since I tapped it earlier) and ran a 5/16th hose back to the degas tank. It's pretty easy to do when you have an R with a cage, it's a straight shot. I tee'd it in with a 5/16th, 3 port adapter to Wayne's coolant mod hose, then to the degas tank. This is the first time I am confident there are no air pockets in the system. The Airlift, Wayne's mod, and the new hose run from radiator made the burping process much less of a chore without any surprises.
    Both front oil coolers are ducted and working well. No leaks. We will find out Friday if this was a waste of time or not.
    One thing else I'm going to need to do is drill some vent holes on the top of the passenger door. The oil lines that I have running through them need some ventilation, it gets hot in that enclosed door space.
    Thanks- Chad
  6. #1486
    Encinitas, CA
  7. #1487
    Any loss of pressure with 40 feet of oil line?
  8. #1488
    Clovis, Ca
    Nothing on the gauge. Everything looks good.
    Thanks- Chad
  9. #1489
    Denver, CO
    Looks great. I hope everything goes well this Friday. Good luck.
  10. #1490
    I cant wait to hear the results. Stoked you found the blown fan fuse.
    All the best!
  11. #1491
    Clovis, Ca
    T-minus 20 min- a nice 80 degrees today.
    http://imgur.com/G43YTRl
    Thanks- Chad
  12. #1492
    Feb 2014
    Ramona, CA
    looks great.
    May your lap and oil temps be low.
  13. #1493
    just got a turboner from that picture.
    be cool.
  14. #1494
    San Diego Ca 92106
    Ditto be cool.
    Don't know if it's Comic-Con being in town or what but the first thing I thought of when I saw the umbrella in the car was what is Dark Helmet doing in the car? :rolleyes
  15. #1495
    Duct tape rolls holding the umbrella down... Is there anything duct tape can't do?
  16. #1496
    Clovis, Ca
    Alright fella's. I think I'm done with this car. I like racing better that wrenching. Same issues. I'll sell it complete, or as a roller. Make reasonable offers. Stress reasonable. The car handles like a dream- I was passing Porsche cup cars again.
    The Good Ole' reliable Porsche is coming out of retirement.
    Thanks- Chad
  17. #1497
    Oh man that's bad news. Creeping water and oil temps?
  18. #1498
    Clovis, Ca
    Quote Originally Posted by Flamshackle View Post
    Ran 30min fine, then the same ole thing. Oil, not water.
    Thanks- Chad
  19. #1499
    Oh crap. That really sucks like hell. So sorry about that. Hopefully she goes in other good hands.
    Which Porsche is coming out of retirement? Would be nice seeing a GT3 RS 4.0.
  20. #1500
    San Diego Ca 92106
    Oh man, this doesn't seem real! You've done everything imaginable. (over kill some would say) From what you've put in the car you would think you'd have problems getting to temperature.
  21. #1501
    NoVA
    Any new video?
    30 minutes to reach the danger zone is much longer than before, right? Some have argued it's the location of the temp sensor. But changing the amount of time it took to reach the danger zone would prove that sensor location isn't dictating temp readings. I guess that's only with everything else being equal (ambient temp).
  22. #1502
    After second thought, I think it's worth pursuing investigation. I would not let go, I would not accept being beaten by one car problem I can't find/fix.
    Let's try thinking out of the box, I have a few ideas, some may be costly, but if they are winners, I personally would do it. But it's up to you of course, it's your car. It's just that I think it's worth it, you've put so much time on it, everything runs fine and it's a blast to drive, it's just that one thing to fix.
  23. #1503
    Huntsville, Al
    Yep I am saying there is something else going on...wrong place for the sensor or bad sensor. ..no possible way it's actually that hot if you engine is healthy..
  24. #1504
    Mechie3's Avatar
    I'm still baffled that you have these problems while quite a few tracked subarus don't. Sorry to bear of your troubles.
    Zero Decibel Motorsports
  25. #1505
    Did he ever change the sensor?
  26. #1506
    Exeter R.I
    No way temps are that high, something's reading wrong brother.
    I beat the hell out of mine today and temps didn't get to hot
  27. #1507
    Clovis, Ca
    Sensor is fine guys. Repeat: sensor is fine. It's something else.
    Thanks- Chad
  28. #1508
    This is what I was thinking.
    The track Subarus here in Aotearoa don't have that much real estate in the oil cooling department. it has to be something else.
    Please don't throw in the towel on this car. surely its worth getting it sorted after all that work.
    Great to hear that it handles like a beast.
  29. #1509
    Suisun City, CA
    IMHO, you need more data. Temp before and after each cooler. If the cooler efficiencies are within proper range, there's something wrong with the engine... Either clearances, or you need to play around with oil viscosity. Don't give up.
    818S - #67 (SOLD IT!)
    Delivered: 18 November 2013
    Go Karted: 29 December 2013
    Finished: NEVER!
  30. #1510
    Things I have learned in 20 years of racing.
    #1 Racing isn't cheap
    #2 Do it right the first time, otherwise it will cost you twice as much
    #3 Read #1 again
    #4 Prepare for the worst
    #5 Have fun
    Let your own learning guide you through this Chad. We are all wanting this thing to be rewarding but if you give up now you will just resent it forever. Fix it, have fun and then sell it. Its the best way forward trust me.
  31. #1511
    Senior Member Tamra's Avatar
    Apr 2014
    Shelton, CT
    Chad,
    I'm sure i'm coming in late, and going over old news to you, and I haven't searched the thread for my answers.
    What are your bearing clearances, is your motor AVCS, and what oil pump are you running, with what bypass pressure/shim count (and ideally, what RPM do you see it hit bypass pressure, and what RPM do you run most of the time on the track average?)
    Other ideas- any chance you could log temps into & out of your oil cooler? Would show where the problem is coming from (heat generation or rejection)
    Reasons I'm asking- the oil bypass generates heat. Too much pump for the oiling needs causes more bypass. Could be that the cooler isn't flowing enough oil (is all the pumped oil passing through the cooler?), or that it's not getting enough air.
    Quote Originally Posted by JeromeS13 View Post
    I agree with the above.
    Tamra
    First autocross 3/29/15
  32. #1512
    Clovis, Ca
    The motor came from AJW. They never called me back when I asked about bearings ect. I'm guessing the bearings are stock for a 2013 sti block. Oil pump is stock. forged pistons, rods.
    I think it is ECU related. It ran fine with the oil temp a 220 for 30 min, then if feels like there is a "timer" on the motor, after a certain amount of time, it starts to lose power and the oil temp starts climbing. This time it started loosing power, the oil temp was still fine for a bit unlike before, then I let off and started cruising to come in, and the oil temp started rising. Could be fuel getting warm too.
    I'm just tired of throwing money at this car. I have other things I want to do/build. I'm still not sold on the safety of an open top car either (especially the R is stock form). I'm thinking $25k as a roller complete with everything without the engine. I'll include everything else- iWire harness for 2006 wrx, Legacy GT trans with LSD (Modena)) Element tuning Dry sump, fire system, Fuel Safe fuel cell, AWIC, 2 complete sets of Team Dynamic racing wheels (one with brand new never used Hoosier A7's) and all the other "new" stuff since my car was a non donor build. All you need to do is throw your engine in. If you want the complete car with motor $29K (Tial External Wastegate, Blouch DOM 1.5.). Comes with NASA ST2 logbook and 2015 Annual Tech sticker.
    I also have an extra Legacy GT trans for a spare.
    Thanks- Chad
  33. #1513
    NoVA
    FFR should pick this up and put their team behind it. It would be a great place for them to start from.
  34. #1514
    Sgt.Gator's Avatar
    Bend, Oregon
    I understand your frustration and need to move on. I'm sorry to see you in this pickle.
    The only thing I can think of is to move the oil tank to the front of the car, away from the engine bay.
    I cancelled my R order and year ago but your car is tempting and it's not that far away for me to drive down with my trailer. Unfortunately I bought a California 2008 Spec B that was someone else's 3 year headache, and now it's my headache. Once the Spec B is fixed and sold I will consider taking on this problem child if you still have it.
    BTW, I used to race with Zack, the Corvette you match times with. He's a great guy. He co-drove my Legacy in an enduro with me last year. Please tell him Gator says hello!
    Don't hate on Corvettes, the ones that race don't wear gold chains and pinkie rings!
    Owner: Colonel Red Racing
    818R ICSCC SPM
  35. #1515
    Hi Chad,
    I know you are getting lot of advice, so I will make this short.
    Is it possible the scavenge pump is not keeping up, allowing oil to build up in the block?
    The crankshaft turning in a pool of oil would fell like a big power loss.
    This would also take all that lost power and super heat the oil in the block. Like a water-brake dyno.
  36. #1516
    Clovis, Ca
    Hi Chad,
    Could be. I'm just at a loss. I had a engineer racer buddy send me this. He thinks I could be "Whipping" the oil. This makes more sense, but then again who knows?
    Thanks- Chad
  37. #1517
    Sgt.Gator's Avatar
    Bend, Oregon
    I think air mixed into a froth causes a loss of oil pressure which should be obvious before it gets too hot.
    818R ICSCC SPM
  38. #1518
    Kitchener, ON
    Metalmaker, Bob, Tamra, what oil viscosity are you running in your engines?
    Chad did you ever try a XX-30 oil?
    If you oil temp is going up and you water temp is constant or going down (like when you backed off to go in the pits) the heat is coming from something in your oil's path, or the oil itself is causing the problem, plain and simple. Did you ever open the engine to inspect for premature wear in any bearings?
    XX-50 oil has ~twice the viscosity of XX-30 at very high temps. This isn't always a good thing. In tight tolerance bearings you can get shearing with higher viscosity. Higher temps lead to tighter tolerances.
    Shearing -> Loss of lubrication -> Heat -> Even tighter tolerances -> More shearing.
    Last edited by dirty kurty; 07-11-2015 at 05:11 PM. Reason: I have terrible spelling.
  39. #1519
    Quote Originally Posted by dirty kurty View Post
    I'm running Rotella T6 Full Synthetic 5w-40. Recommended by my Tuner ( https://turninconcepts.com/ )
    I don't run nearly as hard as Chad. The hardest I have done so far is 12 autocross runs in a 1 hour period.
  40. #1520
    Santa Rosa CA
    Sorry things didn't work out Chad. I kind of had my doubts at the third oil cooler. I track and autocross my turbo Mustang and I can tell you there is a lot more abuse on the open track, If you have watched Chad's videos he is close to 7k all the time. Most of my time is at Sonoma where you are only at full throttle about half the time. Autcross is short bursts with a long wait. The point is that Chad is stressing everything to the max. (including Chad). I think on one hand you are right Chad, you may not need to sell it, but you need to step away from it. Race the Porsche and enjoy the rest of the Summer. Maybe some of us will catch up to you and solve some of these problems. Thanks for your effort. Is crowd funding still an option?
