Wayne,
Keep us posted on how quick you can build this.
Is this car going to be stock or will it get all the VCP goodies?
Does this car go back to the customer or are you going to race it?
you got a steal on these parts... looking forward to seeing this buildup.
Warning to Newbies: One hour of Wayne's work equals one week of work by us normal guys.
It took us 19 hours to have a roller with the steering rack and pedal box installed. Wayne is super human.
Tamra
First autocross 3/29/15
All of the brake and clutch lines were done in that 4 hours too
He doesn't have to waste all that time where we look at what we have and have to figure out what to do, he has been there before. My second body install was more than 5x as fast.
Dan
Well nothing to report today as work got in the way of the 818...
Boo work!
Go speed racer go!
Zero Decibel Motorsports
Check out my new website!
At this rate your going to be go karting this weekend.
Here is the 10 hours compressed into 5.5 min...
Huh... Looks like regular speed to me. Where's the rest of the 9.9hrs.
7 days?
First, how can you build something in 7 days when it takes us 1-2 years and second are your days 12-15h or 24h of work? Just kidding. That's going to be an awesome challenge! Let's see in 4 days! Clock is ticking Wayne, go back to work.
Tracked May 27/July 26, 2017
Build Completed Winter 2021
Ha, maybe I should have said 7 work days. I have to get parts out the door for you guys in between
Here's your motivation, not going to happen!!!
Dang!!! go on with your BBBAAAADDD self!
Nolan
Any concern with the amount of weight hanging over behind the rear set of jack stands in that video? The entire motor/trans is behind that plane at one point without much up front (say about the 3 minute 11 second mark for example).
Just curious since I will be finishing off some of the underbody aluminum panels, etc in the coming weeks and I have generally put my lift arms back near the motor mounts. Won't be able to do that soon.
Thanks!
I've actually found that where Wayne has his jack stands is just about the center of gravity. When I support mine there I can lift either end with barely any effort.
I went to the front of the car and lifted by the radiator support while standing on a scale and it took 142 lbs of additional lifting to hold the front end.
awesome. thanks for the quick responses.
I use the same points
Dan
I love those brakes! But they don't look like the 6-piston ones, they look 4-piston with black discs.
2 days left. Or about...
Wayne you lost your bet unless....???
Thanks- Chad
How is the project coming? its like my favorite TV show got cancelled mid-season
I've been slammed at work, prepping 2 race cars, helping a friend change a motor in his 07 F150 4wd and was at the Ultimate Track Car Challenge yesterday. GM gave GRM a "track ready" 2016 Camaro to play with and I got 25 laps in it yesterday.
How come that Camaro doesn't want to go around the corners like an 818?
Wayne, how does this 7-day R look like, now?
It will be complete after the 66 fast back and a customer 818 are done. Something about real work getting in the way of fun work.
off topic but Wayne how do you keep your bottom hose from rubbing the bellows? or has this rub been corrected?
I'm using the hard lines and the rub is so slight that it's a non issue.
I have the hard line too, and my rub was very minor, but I figured it would be worse when the car was lowered as the tierods will come up. I got Rori's spacer and I have a 1/4" now.
TY.
