Results 1 to 12 of 12
Thread: Coupe gripes
    Coupe gripes
    So for you all you out there with a coupe, what do you think is your biggest gripe or complaint?
    Gorham, ME
    That it isn't done yet!! LOL
    If anything the manual will not get you through everything you need, but that is where this and the other forum are your life line. Don't expect OEM fit and finish (i.e. doors), but as far as kitcars go this is a good kit.
    Fresno, CA
    That I built a roadster before a coupe!
    Doug
    Built FFR5196 MKII in 2003, 427w
    Building FFR0058HR, Edlebrock 347-AOD
    Cobra Driver UpstateCobraGuy's Avatar
    East Greenbush, NY
    I don't have one...
    Mark III 4630RD Explorer 302, Holley SA570, FRPP B-cam, 4 to 4's, 3 Link, Bullitt wheels, Baer Brakes, 3.73 gears, HD T-5
    Mark II Rebuilt into 1955 Jaguar D Type Replica Explorer 302, Holley SA670, Trick Flow Stage 1 cam, 3 Link 4.10 gears, Classic Gauges
    PM me if you live in Upstate New York. Get added to the "Upstate Cobras" email list. 60+ members!
    wallace18's Avatar
    Trenton, Florida
    Hard to get in and out of. And a little on the loud side. Other than those 2 things I like it a lot.
    The worst part is all the attention you draw wherever you go! HaHa! I miss my coupe! Seriously, though, they get pretty hot inside.
    Senior Member turbonut48's Avatar
    Milwaukee, Wi.
    Nobody knows what it is !!
    And yes its hot !
    The Nut
    Green Bay WI
    Hot, especially at WOT; you can feel the exhaust heat up around you. It is nice on the open road though as the interior is relatively calm at speed. The random attention that it creates, and of course the heavy metal music which is great, but earplugs are a good thing!
    Nice
    Quote Originally Posted by Shawnski View Post
    Shawn
    What is the color on that coupe, it really shows off the curves the way the light plays on it.
    DB
    Hemi33
    Senior Member snakebit31's Avatar
    Virginia Beach, VA
    It's hot, and quite a bit louder than the roadster.
    Rob
    Green Bay WI
    Quote Originally Posted by myjones View Post
    Shawn
    DB
    Hemi33
    Its based on Summit Racing's Carbon Fiber metallic. It was mixed locally; base coat, clear coat.
    Senior Member GThompson's Avatar
    Spencerport, NY
    Cost of body-work. So far I've only gotten 2 quotes and they're both north of $14k. If I ever get around to building a new workshop (now on the fence on that because the quotes I've gotten for that have all been over $75k (32x48 stick-build building)) I may take a shot at painting it myself.
    George T
    Type 65 Coupe #338, Picked Up 4-Aug-07, Roller on 8-Mar-09, 1st start 8-Sep-13, 1st Autocross 7-Oct-18, finished sanding & sprayed paint myself 6-Nov-21, IRS/LCA/Koni/traditional gages/Kirkey/pin-drive rear width/15" Torq-Thrust Ds/44IDFs/Brodix ST5.0R heads/Eagle internal-balance crankshaft/oil pan by Armando/home-made turkey pan/S-10 mid-shift T5
