0
0
2. 5 n/a engine not running correctly
does anyone have the correct settings for my computer for this engine? i have a tech s computer and have been ablle to connect it with the car but the engine is way too rich
and wont run right. Any help would be appreciated. my car is finally ready to rrive if i can get this engine problem solved. I am not a computer capable mechanic. too old i guess
kerry 765 - 635- 7949 anderson, indiana
I suggest you find a tuner with a wheel dyno near you. IMO it is the only way to get it right the first time. I did that with my first 818S with Wayne and it came out perfect.
Administrator
Kerry,
Just left a message for you. I am not sure if the N/A cars have the Tumble Generator Valves (TGV) but do know that was my problem with my turbo charged car. Took them out and all was well. You can look up Subaru TGV delete on Google and it will give you the details.
Henry
thanks for the reply ill look it up today
kerry
