Hello everyone. This is my first post but not my first experience with the forum. I have accessed the forum very often even before I purchased my complete Mark IV kit. I must say that the site has been quite an asset during my build. I have used a number of ideas and suggestions from the many post I have viewed. I would like to thank those individuals but they are too numerous to mention. However, I would like to thank Jeff Kleiner on his post about the rear quick jack mounts as well as the Speedhut gauges to Ron Francis hook up. Worked out well.
My present issue concerns the Driver side quick jack mounts (front frame horns). The body is centered on the chassis. Sets within the hood opening and the 3/4 tubes, the dash, door latches as well as the rear quick jack mounts, etc. All the weather stripping is attached. All seems well.
However, the driver side quick jack mount is extremely close to the brake duct cut out opening as well as the lower body splash pan. It appears that it needs to be moved (bent) inward toward the radiator by 1/2 inch. The passenger side mount appears to have enough room. Is there a way to move the mount 3/4 tubes inward without bending the frame. Your expertise would be appreciated.
Tom T
