0
0
#139 4.6, 6-71 engine issues
After a long wait and not working on the car much through the summer, I had a full day to get the engine started. With a turn of the key the engine fired up and went dead. I was not to concerned since I knew I was going to have to do some turning. Then I head what sounded like the timing chain sliding over the gears. I have a DOHC 4.6 engine. After an investigation, the secondary timing chain broke. This means seized cam shaft and bent valves. Looks like another 6 months behind schedule.
Rod
