Results 1 to 13 of 13
Thread: Has anyone else besides FFR drag raced? Full 1,320'?
    Feb 2013
    Westminster, MD
    Best $3 I've ever spent!!!
    Senior Member 6t8dart's Avatar
    Apr 2015
    Irving, TX
    Holy cow! Thats fast!
    Leesburg, VA
    Very nice, got video?
    Senior Member Mike N's Avatar
    Mooresville NC
    With a bit more traction that's an easy mid 11 second ride. And with traction a mid 3 second 0-60. Very nice.
    Mike............
    Feb 2013
    Westminster, MD
    Video - https://www.youtube.com/watch?v=stQD...ature=youtu.be
    Thanks!
    This was on street tires with full aero too. I'm positive that if I went back with some taller radials and got that 60' down to 1.8-1.9 it would be a mid/low 11. I managed a 2.0 60' my last run but missed 4th gear. A tenth on the 60' is 3 on top, so that could have been an 11.6 second run. Being able to keep it in 4th would help too, you lose a tenth or more per shift.
    Not bad for a car that is NOT intended for drag racing at all.
    Leesburg, VA
    Quote Originally Posted by SixStar View Post
    Sweeeet! Thanks. Did you let off throttle a bit at launch or was that traction control?
    Bowling Green, KY
    At 5380' to boot.
    Feb 2013
    Westminster, MD
    At 5380' to boot.
    With an 8,900' DA!
    Bog. 4k launch. Next run it blew them off though. Street tires are temperamental.
    Exeter R.I
    I have done some street runs and came close to what your getting. I feel on a strip I could pull a low 11 or high ten with right tires and practice. I got 8,500 top end which helps me hold the gears longer and shift less. I get to like almost 140 in 4th. Very nice bro!!!!!
    My only complaint is how the car drives on average roads. It loves to chase the uneven pavement and makes it hard to drive if the road is not really nice. Maybe a bump steer kit and more precise alignment.... More caster, corner weighted.. Idk. I think I just have to tune the suspension more.... Ah more time
    Clovis, Ca
    You could fix that with all that you stated. My car does not chase pavement when I secretly run through the hills
    Thanks- Chad
    Jul 2012
    Encinitas, CA
    It's the 818 blues...
    What are optimum suspension alignment specs. to avoid the tramlining that you mention? My 818S too is scary to drive on all but perfectly flat pavement. What bump steer kit?
    Bowling Green, KY
    I got the Baer bumpsteer kit from Summit Racing.
