![Very Cool Parts](https://thefactoryfiveforum.com/attachment.php?attachmentid=40527&d=1428867450)
Replicar Deliemma
I'm currently working on a 289 FIA FFR roadster replica. I am working on the form to get it registered in Pennsylvania and found certain things that are driving me nuts. I'm attempting to build a replica of the original with just a few modern touches, mainly for ease of operation. But now I find that I'm required to have bumpers, defroster, wipers (which I am installing) and backup light.
Since this is a 289 body will the standard MkIV bumpers fit?
I'm install a small off-road LED light just under the body but I hope above the X-zone required by the state.
I'm check with the state about the requirement of a defroster on a topless vehicle.
Has anyone else had these prblems?
Not a waxer
Send a message to my friend "FMJ" (Fred) here. He recently went through the Pennsylvania registration and inspection process and may be able to answer some of your questions. I know that regarding bumpers he maintained that the quick jacks were indeed just that and as far as I'm aware the inspectors agreed.
I just went thru PA title/registration, with my plate/registration arriving 7/22 after 5 weeks of Harrisburg.
- Yes, bumpers are required for the enhanced inspection and the annual inspection you get after you get the registration. Can you get a ticket if you don't have it on between annual inspection? Sure ... but WOULD that happen?
- Yes, defrosters are required, as are wipers.
- Download the Special Construction fact sheet, Subchapter K and Pub 45 from the DMV website. Subchapter E applies to passenger car inspections and special construction vehicles also.
Thanks for the help but will the standard Mark IV bumpers fit my 289 body?
I am not sure. What is the spacing between the front and rear quickjack holes, both horizontal and vertical?
Where are you located in PA? There are at least 4 Mk4 in the Lock Haven/Williamsport/Sunbury general area. I am up for a drive if you want to look/compare.
Husband/father/son
Where in PA are you located?
Bill S.
I'm in Bristol, PA, NE of Philadelphia.
Husband/father/son
retropt
Bristol Penn Jersey Auto 215-946-1833 should be able to do the enhanced inspection for you. Give them a call as they are just up the road in Levittown
Bill S.
Just up the street from me thanks.
![Stewart Transport](https://thefactoryfiveforum.com/attachment.php?attachmentid=40533&d=1428868052)
