Good luck on the maiden track day! Looking forward to your report
Put some rubber tubing held on with some duct tape in those rear brake line notches you made. You will be amazed how much stuff moves. You don't want anything to cut those.
I rub my tires on the top of the aluminum during hard cornering. You may have to raise them a bit more.
Thanks- Chad
Lunch time update- this car is incredible. Dialing it and myself in. Very nice track and awesome instruction. Included bbq lunch. Hopefully it keeps doing well for the afternoon session. This is some of the most fun I've ever had.
Nice, how are temps? This is a road race course not auto cross right?
Whoo hoo!!! Looking forward to more updates and video later!!!!
Tamra
First autocross 3/29/15
This is a 2.1 mile road course. 20 minute sessions. ~115-120 on the straight. The car is definitely heatsoaked. Especially when I stop to pit or pick up a passenger (instructor and girlfriend haha). Oil and coolant temps are very normal. Hasn't left the range it was at in autox yet. Definitely needs more aero, more tire, more camber, and a lot more driver mod.
That's encouraging!
Okay! Last quick post; next one will be big and ful of fun things. 3-3.5 hour drive home plus dinner hen unloading means it'll prolly be tomorrow, though. Shifter broke on the very last lap. Left me stuck in third. So I finished in third and loaded her on the trailer. Sounds like I have to look at that. Amazing day though. Only serious issue was a shifter cable at the very end of the day! Awesome first track day in the 818.
super awesome news! can't wait for the full report. Safe drive home!
Okay, the full report!
First, here's a video. It's pretty fun. My lines got MUCH better as the day went on and my confidence in the car/knowledge of the track increased.
The good:
The car held up extremely well, I think. Amazing track, too. Can't say enough good things about both the staff and the physical track. Perfect surface, very grippy (some patented polymer blend into the asphalt), lots of track time with good turnovers, good instruction, good bbq lunch (included). I might just buy a season pass, actually. Total track time was about 2:15, which is more seat time than I've had in it for sure. The car handles speed very well. Stable at full speed (easy 120 down the straight with no passenger), loves the corners, and really lets you know what it's doing. I took a few enthusiastic passengers (including both an instructor and my girlfriend) for rides and everyone loved it. The car got a lot of attention, too. Almost everyone there talked to me about it at one point or another, and I even had the instructors saying how much fun it was/fast it is. I definitely am not enough of a driver for it, yet. I'm sure lots of people have pictures of the car, so here is one of my favorites of the ones I've seen so far:
The bad:
Needs an LSD. I could tell it was only doing 1 wheel peel stuff exiting some corners. Definitely on the mod list. Also on the mod list is a tighter shifter, because I missed 4th twice (Chad knows my pain, I believe) and was not always confident on gear changes, which really distracts you from driving well. I also would like to check out the car with more aero, more camber, and much more tire. My small street tires were fine, but left a little to be desired. Also, slight fender liner rub on my driver's side lateral link. No big deal; just needs a little trim.
The broken:
On the second to last lap of the day, the cable shifter broke and left me stranded in third gear. I finished the lap and went into the pits. Inspecting the cable today, but it's the forward-backwards cable that broke; the side-to-side one still functions. My girlfriend was going to drive it (she has more track experience than I) at the end of the day but this disabled the car so we loaded and left.
Nice to see another R on the track!
Was it the FFR supplied cable that broke? Did it actually break the cable or did a fitting come off/break?
Do you have data logging? I think we'd all like to see lots of temp logs.
Good stuff!
Owner: Colonel Red Racing
818R ICSCC SPM
The cable broke? Where did it break? I mean I know it broke on the race track, I mean which part of the cable.
Tracked May 27/July 26, 2017
Build Completed Winter 2021
Looks like a lot of fun! No sweat on the cable breaking I guess, since you want a slicker shifter, you'll need new cables anyway.
Glad all the temps stayed well. That is promising.
Haha, Frank I was going to say "between turns 6 and 7!".
This is the part that broke:
This is FFR shift cable on the shifter end, not the trans end. I don't know why it broke, but I can't imagine I mounted this part incorrectly. It's a vague shifter to begin with, so I guess my upgrade is just forced a little early. Anyone have experience with other shifters? I was looking at the K-tuned one. I'm sure Wayne can chime in.
I do not have my logs. I didn't make enough room on my AP before going to the session, and don't have a way to monitor it with my tactrix other than a laptop. I was plugging into it in between sessions and looking at temps. Coolant was under 200 each session.
Thanks for the support, guys. It's really starting to come together. I have another track day in 2 weeks (well, track weekend actually. Friday-Sunday at SLMP), and plan to do a few things by then. Fix my shifter and my truck's exhaust are the biggest ones, though!
Thanks for the vid! Inspiration to keep plugging away.
Looks/Sounds like a great time at a nice track -a perfect day. Glad your shakedown only had the shifter cable issue & that everything else worked out to your satisfaction.
Great news on your successful track day, congratulations.
Hey Frank,
Glad to see you had a great first track day. Michael and I are looking forward to the same.
I can think of a few reasons I've seen cable fail at that point. Not in particular order.
1. Manufacturing defect. (over crimped.)
2. To much bend at the point of breakage. (You want that joint to be as straight as possible)
3. Electrical current. (forgetting engine strap ground puts current through cable)
4. more force than the cable was designed for.
5. Lack of lubrication (manufacture defect)
if the wire strands kind of look melted at the tips. I would look at #3.
With a to sharp of bend, one stand will break or pull out. Mucking up all the others.
Thanks guys, it means a lot to me! It's incentive for me to keep working on her, too. It's DEFINITELY worth all the late nights, frustration, and confusion.
Bob, good suggestions. The ends are all sharp and definitely look sheared. Hopefully this rules out #3. Since it's the FFR shifter side, there's not much I can do to adjust the bend at this point. But it does look like too bend here or perhaps a manufacturing defect. I'm thinking rather than risk it (and also risk missing a shift with the vagueness of the shifter), I'll just upgrade to one with more feel. Again, definitely looks sheared here to me. The shifter felt bad for maybe ~10 laps before it broke. Perhaps one strand of cable broke before the rest of them did.
When is your and Michael's first track day, Bob?
We have 10 days before registration, We don't want break anything before then.
We are pretty confident about autocross as we did 72 runs last Saturday and Sunday without issues.
I would like to get a data logging system running first to monitor all the temperatures.
Awesome! 72 is a lot of runs for 2 autoxs (18 runs per driver per day?). After my day, I recommend checking all fluid levels between each session (gas, oil, trans fluid, coolant, at least). Data logging would be cool. So would GoPro footage
Best of luck, Bob. I look forward to hearing about your first time on track with the car.
Also, for any R builders, I strongly recommend either a hoodie or at least long sleeves (it was cold in the morning) if you don't have a suit. Gloves would be nice, too. Stuff sometimes comes up and hits you while you're driving. I assume those with windshields don't have to worry about that part.
It's so cool to see that even though things are breaking you are full of joy. That means, like you said, the car is worth the hassles so that you can drive it!
I have a set of FFR cables I won't be using or need (MR2 Shifter) if you need one or both to get you back on the road.
Mitch, I sent you a message. If you're not going to use them I would love to have them (probably both as a spare in case this happens again) as I'm tracking again in less than 2 weeks. I called FFR and they want to see photos of how this failed and maybe get the cable back in. I feel like it might be a manufacturing defect. FFR's former co-op (Frank) installed the shifter with me back in the day, so even more reason to assume it was not an installation error.
Got your message PM me your address and I will get them out to you tomorrow.
Glad to help,
Mitch
Frank that session looked really fun and the car looked great! Also, I'm guessing you didn't have any issues running the TMIC?
Upgrading the shifter is a great idea. I went the MR2 route with shorter cables - it's a bit cheaper than the k-tuned setup and not as plug-and-play but I think has a very similar feel.
Thanks again, Mitch
It did heat soak when I sat in the pits after running then went back out. I don't have the top piece on it, though. So it's allowing a lot of air to pass by.
I'm gonna go through my next track day with the stock shifter and Mitch's cables. I'll look into an upgrade either way over winter, I think. I like the MR2 route better financially.
Haha. I was going to say...it's definitely cheaper for me to drive almost anywhere in QC than it is to ship something. Plus it'd be much faster.
So many Franks. I'm "Frank 3" to my friends. Frank 1 worked at FFR and has a 5.0 in his Nissan 240. Frank 2 is building a Honda swapped Fiero.... we all do some weird car things.
And I know another Frank, at DriveShaftShop, he does the axle bars for FFR and any custom driveshaft one wants (including mines, which will cost less than expected). I don't know what he drives, though...
About the bumper vents, we still don't know if they really work?
This is how: http://www.autospeed.com/cms/article.html?&A=111111
I bought one of these to do the testing, and of course wool tufts too.
http://www.amazon.com/Meters-PDMM01-...0_SR160%2C160_
818R ICSCC SPM
Did some suspension adjustment and took care of a serious wasp infestation in the house. Man, I can't stand nature sometimes.
Also installed my E-brake handle. But it seems I don't have the piece that connects to the Factory Five provided metal cover (and originally the frame). Does anyone know what that part looks like?
