Page 8 of 10 FirstFirst ... 678910 LastLast
Results 281 to 320 of 393
Thread: nkw8181's 818 build thread
  1. #281
    The black stuff is carbon fiber? You must have paid a fortune for that or not?
  2. #282
    nkw8181's Avatar
    Dallas, TX
    It is second hand so a bit cheaper. ~22 $ per yard by 50 in wide.
    I moved it back so i didn't need to cut such a big cutout in the engine cover. The front hasn't been fitted fully yet but i think I can make it work once i get the door part sorted. You can see there wasn't much material taken from the engine cover.
    Nolan
  3. #283
    nkw8181's Avatar
    Dallas, TX
    Nolan
  4. #284
    Does it really stiffen enough so that you can pull up the front hood without it jiggling?
  5. #285
    nkw8181's Avatar
    Dallas, TX
    I haven't mounted it yet but it is a world stiffer. It may still flex a little but I would guess that there is a 75% reduction in flexing at least
    Nolan
  6. #286
    Feb 2014
    Ramona, CA
    Great work on the panel stiffening! I did the same but with aluminum bar and fiberglass. I like your solution way better. I'll copy you on the trunk and engine cover.
  7. #287
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    That looks like a good option. If you are looking for additional ideas to strengthen, you could use balsa wood like they did on the old Porsche 914-6 hoods and deck lids:
    http://www.pbase.com/9146gt/factory_...ood_trunk_lids
  8. #288
    What concerns me is that if we need to bend a little some panels, like the hood for instance to clear the single wiper solution, maybe it won't bend enough anymore with the CF inside. And it's pretty hard to apply the CF while the hood is on and closed.
  9. #289
    My hood fits over a single wiper with no mods.
    You should have your hood on and closed while it dries so it forms to the car.
  10. #290
    nkw8181's Avatar
    Dallas, TX
    Ops I didn't do that (the hood on the car while drying) but I think I'll try that on the others. Just tricky to put it is place at the right time. Basically once it is tacky. I did support my hood as close as I could to its installed shape. Balsa wood is a great idea! And may be easier to work with. Carbon fiber really likes something to adhear to. It doesn't like thin air.
    Nolan
  11. #291
    Quote Originally Posted by nkw8181 View Post
    Nolan
    I used 1/2 by 3/4 balsa standing on edge for the front edge of my humps. The humps were weak at the 4 roll bar cut outs.
    I did have to notch the balsa some to clear the roll bars.
  12. #292
    Ok! That's cool to know.
  13. #293
    nkw8181's Avatar
    Dallas, TX
    Gonna try photobucket vs imgur. So I got the doors mounted and Bob I used your idea of balsa wood for this last part. It is stiff enough that I can lower the hood down with one corner and the other side touches at the same (or close enough). Enjoy
    http://s156.photobucket.com/user/nkw...bile%20Uploads
    Nolan
  14. #294
    nkw8181's Avatar
    Dallas, TX
    Picked up a 6 speed. something I want to point out and I mentioned this to Factory Five already as well. The FF 6 speed conversion only works on a trans with a DCCD and the last three digits of the dccd being 190. The internal trans pics are from a 05 JDM spec C. Luckily I was able to swap it out for an 06 JDM STI and conversion done. Engine is still at the machine shop the last time Auto Science (my local shop) checked So I've been making progress on the body. Since I moved the body back an additional .5 in I ended up making new latch mounting brackets. Got started on installing all Zero decibels louvers so i can get them all powdercoated.
    Nolan
  15. #295
    Senior Member TX-Lou's Avatar
    Nolan had recommended Auto Science to me for our engine rebuild and I dropped off our engine and transmission there yesterday. He had also invited my son and I over to take a look at his 818S so we headed over afterwards.
    Nolan is doing some great work on that car and it looks fantastic. I really appreciate the opportunity to see his build and be on the receiving end of so much advice and lessons learned. It will all be very helpful for when our kit arrives.
    I just wanted to say Thanks again Nolan!
    - Lou
  16. #296
    nkw8181's Avatar
    Dallas, TX
    It was great having y'all and talking shop. Looking forward to seeing your build.
    Nolan
  17. #297
    nkw8181's Avatar
    Dallas, TX
    Made the cuts for the engine louvers and got them temp installed. Also went by my local shop (Autoscience) to see how my engine build was progressing. Some parts where finished being cleaned. SHINNY!
    The other pics are seen if you click on the pic
    Nolan
  18. #298
    Senior Member NBinSD's Avatar
    Sep 2014
    Your cuts for the hump vents look great. What method/tools are you using for the fiberglass cuts?
  19. #299
    nkw8181's Avatar
    Dallas, TX
    Thanks! A Dremel with a cutting wheel and sanding wheel. Makes a mess but worked well for me.
    Nolan
  20. #300
    nkw8181's Avatar
    Dallas, TX
    Got the frame mods for the 6 speed done as well as installed my injectors and fuel rails.
    Nolan
  21. #301
    nkw8181's Avatar
    Dallas, TX
    Nolan
  22. #302
    Hindsight's Avatar
    Atlanta
    Nice choice on the fuel rails. Frame mods look great too... very stout.
  23. #303
    nkw8181's Avatar
    Dallas, TX
    Thanks, I learned the cost is in the lines/connectors more then the fuel rails.
    Nolan
  24. #304
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Don't you mean wires?
  25. #305
    nkw8181's Avatar
    Dallas, TX
    Haha I got it right in written form lol
    Nolan
  26. #306
    nkw8181's Avatar
    Dallas, TX
    Got the engine installed as well as sound deadening the rear panels.
    Nolan
  27. #307
    nkw8181's Avatar
    Dallas, TX
    Wiring! Uhhgggg this is how it currently looks
    Nolan
  28. #308
    Hindsight's Avatar
    Atlanta
    Looks pretty good to me as a start. That job takes forever.
  29. #309
    nkw8181's Avatar
    Dallas, TX
    Wiring done up a little better and fuel system is temp installed looks like I'll need a few shorter hoses but otherwise close.
    Nolan
  30. #310
    Administrator
    Enterprise Alabama
    Is that your fuel pump tie wrapped to the frame or a filter?
  31. #311
    nkw8181's Avatar
    Dallas, TX
    Fuel filter. It may get rearranged a bit
    Nolan
  32. #312
    nkw8181's Avatar
    Dallas, TX
    Rearranged the fuel system and like this solution much better. Put wire protection on some of the wires. Rerouted the turbo blowoff hose to underneath the intake as well as extended it with a radiator male to male 1.25 in adapter and 1.25 hose. Pics to follow
    Nolan
  33. #313
    nkw8181's Avatar
    Dallas, TX
    Nolan
  34. #314
    nkw8181's Avatar
    Dallas, TX
    Nolan
  35. #315
    nkw8181's Avatar
    Dallas, TX
    I thought I had posted an update here. Guess not. So here are some videos of the first and second start after the engine rebuild.
    https://youtu.be/tfIfqlbtKsU
    Nolan
  36. #316
    nkw8181's Avatar
    Dallas, TX
    The first one we stopped because the turbo oil line wasn't tight. The second one is a little long but I figured some would enjoy it. We stopped because of air in the coolant system. I'm the one pushing the accelerator. The guy looking for leaks is my friend Ryan who has been working on the car with me from the beginning.
    https://youtu.be/sjH4jzaXhyI
    Nolan
  37. #317
    nkw8181's Avatar
    Dallas, TX
    Been busy since my last post. 6 speed shifter brackets installed as well as reverse lockout disabled, created a mounted bracket to support the fuel Y blocks, back half of modified center console installed, both seats installed, created mounting brackets for the fuse boxes and the hazard switch, made a bracket to allow the guage cluster to be installed, made new dash mounting brackets (provided ones did not reach) and finally installed the dash which was still a pain. There's about 20 pics showing this below.
    http://imgur.com/a/zLjqy
    Nolan
  38. #318
    Puyallup, WA
    What did you end up plugging the oil port with on the back of the 6 speed?
  39. #319
    nkw8181's Avatar
    Dallas, TX
    I used shelack ( I can't spell it) as shown in the manual for the conversion.
    Nolan
  40. #320
    nkw8181's Avatar
    Dallas, TX
    Or maybe I don't understand. I only plugged what I cut off
    Nolan
