Results 1 to 10 of 10
Thread: electric e brake
    Mar 2015
    Belmar, NJ
    electric e brake
    has anyone installed the e-stopp electric brake system?
    if so can you share pics and opinion
    thanks
    Member 508wrx's Avatar
    Nov 2012
    Taunton, Ma
    I have. Mike Everson has also. Unfortunately these are the only pictures of my install. Its fairly easy to install. I have a second one for sale if your interested.
    post 106
    http://thefactoryfiveforum.com/showt...d-thread/page3
    "aerodynamics is for people who can't build engines" - some old dude
    "Shut up! I know what I'm doing" - some angry finn
    Mar 2015
    Belmar, NJ
    Quote Originally Posted by 508wrx View Post
    post 106
    interested
    [email protected]
    Sep 2014
    Looking at this set up also, I can't verify that it will pass state inspection here in Pa.
    I have been reading the requirements for braking systems on Spec Construction/hot rod/ etc. Only thing covers is this,
    The service brakes shall act
    on all wheels upon application and shall be
    capable of stopping the vehicle in not more than
    the maximum stopping distance prescribed in
    Table I (relating to brake performance). Every
    street rod, specially constructed vehicle and
    reconstructed vehicle shall be equipped with a
    service brake system which is identical to the
    originally manufactured brake system; except, if
    the original system has been modified or the
    street rod has rear tires wider than 9 inches, the
    service brake system shall be of a design that
    rupture or failure of either the front or rear brake
    system will not result in the complete loss of
    braking function. Braking function may be
    obtained by hydraulic or other means through
    a normal brake mechanism. In the event of a
    rupture or failure of actuating force component,
    unaffected brakes shall be capable of applying
    adequate braking force to the vehicle.
    I cant get a straight answer from 2 service stations locally. One said no elec E brake unless it was original equipment.
    The other guy said he has never had that question come up before, and suggest I check on line.
    A little frustrated, to say the least.
    Hershey, PA
    Quote Originally Posted by Innkeepr View Post
    Inkeeper, have you gotten a resolution to this? I am looking to build an 818C and have a electronic ebrake system.
    Nepa
    dual master cylinder reservoirs would work based on how I read it.
    Sep 2014
    Ken,
    Unfortunately I have not, and to be honest - I haven't really pursued it either.
    I am in the process of rebuilding my ej207, and collecting the other parts - as I didn't have a donor.
    Frankfort, IL
    The way I read this section is that it is about the regular brakes, and has nothing to do with the parking brake.
    Senior Member gwarden's Avatar
    Jan 2012
    Surry Va
    Quote Originally Posted by billjr212 View Post
    Thats the way I read it too
    I made my own e brake for under $100 and it passed my local inspection station
    Hershey, PA
    If I jump in on a 818C build, I plan to use a e-stopp unit.
