What: Group buy for hood hinges that swing the hood forward and allow you to eliminate the front hood pins. This version is the version compatible with the coupe front end. It also will work for the S/R original front end if you desire to add a mesh grille and need clearance over the top of the grill. The Coupe style arm is much more swept back to provide the clearance and, as it requires 2x the material it also costs 2x as much for the single piece.
Individuals wishing to upgrade their S/R front end to the coupe front end only need to purchase the arm. All of the existing S/R hinge parts are compatible with the coupe hinge.
Coupe Arm:
Cost:
Full Hinge Setup:
5-9 people: $240
10-14 people: $225
15+ people: $210
Coupe Arm Only (for S/R retrofits)
5-9 people: $70
10-14 people: $59
15+ people: $56
To make it financially easier for existing customers to retrofit, prices for these pieces is only $10 over my actual cost. Mr. wonderful on Shark Tank would call me stupid. Good thing I don't like Mr. Wonderful.
What You Get:
Two hinge bases (laser cut, bent, TIG welded)
Two hinge arms (laser cut)
Two hood brackets (laser cut, bent, TIG welded)
Hood Brace (laser cut, bent)
Rivnuts for frame mounting
Bondable studs for hood mounting
All stainless hardware
Group buy will stay a couple of weeks depending on volume of response. 50% deposit due at the end of group buy. Lead time on parts is roughly 2 weeks after the group buy closes.
Original development and test installs of the S/R style shown here.
Matteos install can be seen here:
http://thefactoryfiveforum.com/showt...l=1#post202454
Dan's install can be seen here:
http://thefactoryfiveforum.com/showt...l=1#post202558
1. Kurk818
2. 07FireBlade
3. TX Lou
4: STiPWRD
5: Redfogo
6: Frank818
7: Metros (arms only)
8: Joseph
9: SnyderJD
10: AZPete (arms only)
11: NB in SD (arms only)
12: cmcintyre
13: 508 WRX (arms only)
14: Newkitguy
15: Phillig
16: FFR ADV
17: 65 Cobra Dude (arms only)
18: Rori
19: PSUalum1986
20: Slatt
21: BN
22: vrumpsh
