I recall seeing a thread with installation of a single windshield wiper. I have been unable to relocate the thread. Can anyone help me find it?
818S #343 Delivered 5-20-2015
First Start 10-17-2015
First Drive 10-17-2017 ( 100 feet back and forth until I can get off driveway)
First Drive with a non leaking tuned motor 11-12-2015 (wow)
Passed NJ State constructed inspection 8/30/2016
This one? http://thefactoryfiveforum.com/showt...d-wipers-818-s
I have a few other helpful links on my site if you ever need them. Trying to build it with as many helpful links as I can for everyone any other links feel free to let me know!
http://redfogo.com/index.php/helpful-links/
Hendow posted this one a while back never looked to see if he has any write ups about it but imo its the best one ive seen
https://www.youtube.com/watch?v=uiW7...ature=youtu.be
Here are some more single wiper links:
Lumpyguy
http://thefactoryfiveforum.com/showt...l=1#post222064
http://thefactoryfiveforum.com/showt...l=1#post211202
Here is my video, No hood trimming needed.
https://youtu.be/U-HMdbagCuE
Erik Treves did one too, the Flash thread for his...
Dan
Thought I would post my windshield wiper mounting. I didn't need any hood trimming either.
I took Lumpyguys arrangement and fine tuned it a bit. Works awesome.
Harley
Bought 2002 Donor Jan 2014
First Start Jan 18, 2015
First Drive Feb 14, 2015
Here is mine. I basically copied Harley, though my attachments are a little different. I used the stock driver's arm. RainX wiper. Raised the rear of the hood using custom brackets that could be removed. Didn't have to cut the hood. Wiper arm came within 1/16" of the remote brake fluid reservoir.... I used the brackets to locate it as low as possible to keep the hood as low as possible. Also note the hood support I added in front to help raise the hood in the middle for wiper arm clearance.
I copied insurance guy:
It involved making a small bracket and using the motor that Bob originally posted. I like the simplicity.
Anyone try to pass inspection with this? in ohio you are allowed manual wipers, I might give it a try.
Hi guys I am fitting the hood to the fenders. For a single wiper what is the minimum height from windshield to the hood?this is what I have now but would like to lower a bit!
Most of us with one wiper have made a hood prop that you can adjust after you get the wiper arm mounted, thus avoiding cutting the hood. You are showing about 2.25" and that's more than I have with my single arm wiper using the donor mechanism and donor arm.
