That is correct.
That is correct.
Should have posted here I guess since it's K-Tuned related.
Wayne what's your experienced opinion on this?
K-Tuned shifter loose?
Tracked May 27/July 26, 2017
Build Completed Winter 2021
OK, I can't seem to get the shifter to shift, I have tried adjusting the damn thing many different times and ways, it seems to move the shifting shaft in/out ok (3 positions) but not side to side. I'm hoping this is not a transmission issue ... Thoughts ???? Getting very frustrated
Tony Nadalin
2018 SOVREN Big Bore Champion
2012 ICSCC ITE Class Champion
818R Build in progress
Yes try to shift it at the gearbox first.
Yes, but that was a while ago, I guess I can try that again, but I assume that the shaft all the way in is 1st/2nd and to the left is 1st, right is 2nd ? and 3rd/4th is in the middle and left is 3rd, right is 4th and all the way out is 5th and reverse, left is 5th, right is reverse ?
Tony Nadalin
Looking at trans from the back: Left rotation is counter clockwise, Right rotation is clockwise
Left In: 1st
Left Out: 2nd
Middle In: 3rd
Middle Out: 4th
Right In: 5th
Right Out: R
And the Subrau 5 speed isn't known for it's buttery feel...
Tony Nadalin
Tony Nadalin
You're not the only one that reversed those at first
Glad it was an easy fix.
N/M: Questions answered.
Edit, thank you
