Thanks Matt,
I had been searching the vintage air catalogs and cant find the evaporator that seems to come with the FFR A/C kits. In a game of inches, I was thinking if the mini evap was significantly smaller, I can put together a kit for a little less, and have more room to work with. It seems the width isnt a huge issue behind the dash, but depth is. At more than 2 inches less depth and the same height, I may try to go this route instead of buying the kit from FFR or North.
VA's mini evap is 19" wide, 7.3" deep, and 9" tall.
http://www.vintageair.com/2015%20Cat...talog%2047.pdf
Would those extra 2" of depth make a signifigant difference in ease of install; dash/firewall mods? Thanks.
Ryan
