Results 1 to 1 of 1
Thread: Coyote engine package BIG DISCOUNTS STARTS FOR MARCH!
    Forte's Parts Connection
    mike forte's Avatar
    Framingham, Ma.
    Hi Guys,
    Thank you in advance for your inquiries and business. March 2016 will have a $600 discount off of the $12,455.00 engine/TKO package now $11,855.00.
    I now have the 2015 IRS knuckles, hubs & IRS 3.55 selling for $1400.00. If you purchase the Coyote,TKO & IRS I still have for $13,100.00
    I've put a Coyote engine package that sells for $12,455.00. Below is the parts list and a few options you might want.
    Ford Racing 2015 Mustang Coyote M-6007-M50A engine, Coyote Electronic/computer, harness kit, Coyote engine cover, Coyote alternator kit, Coyote mini starter motor, Ram 26 spline clutch kit, clutch fork & throw out bearing, clutch mounting hardware, Coyote aluminum bellhousing / block plate & bolt kit, Tremec TKO-600 or TKO-500 (machined to fit FFR chassis), Moroso oil pan & pickup.
    The above parts are all of the parts to assemble your Coyote engine / TKO package
    A few options include:
    8.8 rear axle assembly with 3.55 gears & 11.65" brakes $1725.00
    IRS 8.8 rearend with 3.55 gears & 28 Spl. Eaton diff. $1745.
    NEW Ford Racing 2015 IRS 3.73 rear end & 2015 knuckles & hubs NOW IN STOCK!!!
    Stainless Header 4 into 4 merge headers $1275.00 (no more "J-pipes")
    NEW PRODUCT: Coyote Stainless Header with Cat now available!!!
    K&N air filter & related air inlet parts $176.00
    Fuel pressure regulator $119.00
    Speedo recall tool $175.00
    Walbro 190 LPH in-take fuel pump assembly $190.00
    coolant tank & cap $79.00
    Synchromesh oil 3 qts $30.00
    If any of these parts are of interest I can ship quickly. Please email me for a complete quote.
    Mike Forte
    40 Pearl Street
    Framingham, Mass. 01702
    [email protected]
    508 875 0016
    www.fortesparts.com
    http://www.facebook.com/home.php?#!/...?v=info&ref=ts
    The Early Ford & FE Tremec were also originals from Mike. The Mustang firewall adjustable quadrant kit also is an original from Mike. His latest developments are external slave clutch release conversions & cable release conversions too.
    Tremec Elite Distributor for: T-5, T-56, T-56 Magnum & TKO-500 & TKO-600
    TKO-500 & TKO-600 Midshifter, Front shifter, offset Corvette shifter and more...
    A REAL SPEED SHOP with parts, price & knowledge....
    Est: 1981 selling & building performance parts to build your dream car...
    FORD RACING & QUICKTIME DISTRIBUTOR. NEW 5 LUG AXLES & BRAKE KITS & NEW 8.8\" REAREND IN BOTH IRS & FOX AXLE.
