Behind door #3 is the.... tec3 ecu system.
Did I win the grand prize?!?!?!
Here is a H6 resource thread on nasioc...
http://forums.nasioc.com/forums/show....php?t=1323800
Isn't the Haltech elite 1500 for four cylinders?
What’s different:
• Elite 1500 is ideal for 4 cylinder or 2 rotor engines.
It has 4 fuel and 4 ignition outputs and single knock control.
• Elite 2500 is ideal for 6, 8 cylinder or 3, 4 rotor engines.
It has 8 fuel and 8 ignition outpus and dual knock control.
My wiring plan at the moment is the elite 2500 with painless for the chassis, which is just under the 3k price.
You can run the 1500 on a 6 by pairing injectors and running wasted spark.
I'm a Haltech dealer so buy it from me please
Would the 1500 run the ez36 too?
Ok, on the Haltec website their video of the elite 1500 and 2500 says that the 1500 will run 4cyl full sequential and 6cyl semi sequential. What does that mean and should I care?
Semi sequential means that it is running the injectors. Up on the cylinders that are going up and down together. They will run just as good as a fully sequential system up and to the point where you have such a large injector that you had can't have a short enough pulse width to idle
On the paired cylinders, the spark fires during an exhaust stroke on one side and firing stroke on the other. The cost difference between the 1500 and the 2500 is $500
Thank you Wayne, sometimes the most basic things can confuse me.
Hi all EZ30 guru's
After a burst of impulse buying at an online auction site I'm now the proud owner (until the wife finds out) of a slightly damaged 2006 Outback R with the 3.0R motor
It isn't going in my 818R straight away, as my approval to build is for the 2006 wrx motor, but I'd really appreciate if someone could point me to a link for any relevant factory workshop manual
Cheers
This is a tech manual...
http://phantomotaku.com/SVX/011822-MSA5P0631C.pdf
I ordered Wayne's haltec unit and will be running it on an 07 wrx. I purchased a 08 legacy EZ30 to rebuild and install next winter. Haven't decided if I will run a turbo supercharge it or just run it NA.
Your welcome. This covers up to 2008, if anyone has a link for one for the ez36 2010 and later I'd appreciate it.
maybe here?
http://jdmfsm.info/Auto/Japan/Subaru/
Thanks, so far from a cursory look it looks like what I need.
