![BluePrint Engines](https://www.factoryfive.com/wp-content/uploads/2015/12/BluePrint_Engines_Factory_Five_banner_ad_revised.gif)
0
0
Exhaust gas temp sensor
My donor harness has what looks like a resistor jumpering the exhaust gas temp sensor connector. I assume this would normally plug into a sensor in the exhaust somewhere? I'm guessing my donor had an aftermarket exhaust that didn't have a place for that sensor so the PO did this to not get a code?
How important is this sensor? Is it common to do this?
Skip
Moonlight Performance
I'm not too familiar with those since the later years didn't come with one but check this out:
http://www.clubwrx.net/forums/engine...gt-sensor.html
Sounds like its more of an emissions thing rather than a tuning thing.
Skip
![LCD Gauge Systems](https://thefactoryfiveforum.com/attachment.php?attachmentid=207714&d=1734617469)
