Likes Likes:  6
Page 3 of 4 FirstFirst 1234 LastLast
Results 81 to 120 of 160
Thread: Lumpyguys 818S build
    Quote Originally Posted by Lumpyguy View Post
    Well it was another good day in the garage today, I was going to order the FF wiper kit but then thought I could make my stuff work. fabed up everything with a little guessing and measuring and surprise it works. I did have to cut off just over and inch across the back of the hood but it dressed up nice and will put a little edging on it after paint. I also made 2 support brackets on each side of the motor to support the hood.
    Great Job on the wipers.
    Some how I must of had more space between the hood and wind shield as I didn't cut.
    My nose might be a little extra forward and my windshield is all the way back.
    Great Job,
    Senior Member DSR-3's Avatar
    San Jose, CA
    Nice work. Is that the Subaru wiper gear? Thanks for posting!
    Jul 2014
    Strathroy, Ontario Canada
    yes its all subaru stuff. just had to cut and weld things and make a few brackets, Its funny because I am using aftermarket seats so I re purposed the seat brackets from the kit to make tabs as they wer bent and holes.
    BN's Avatar
    Sept-lies Qc.Canada +FL. Danvenport
    Well done on the wiper
    Yeah pretty nice! I like the cut in the hood, I mean if a cut is required, this is a nice design
    Senior Member TrickyPete's Avatar
    Lewiston ME
    Can you post me a picture of how you mounted that fuse panel under the hood? Mine is ending up in the exact same spot and I'm having issues figuring out a good was to mount it.
  7. #87
    Jul 2014
    sorry it took so long, here are a few pics of the fuse block and the wipers done. Also I got the exhaust all mounted and welded today. Just an FYI only the L side exhausts the Right side are fake tips so I can have a nice looking exhaust that comes thru the bumper and looks factory and even.
  8. #88
    Apr 2015
    Andover, MA
    Wow....nice job with the exhaust. Best I have seen on this forum and will likely influence my approach. Will you be closing off the area around the tips, or are you leaving them open?
  9. #89
    Freeport, ME
    Very nice wiper work, great job!
    Dan
  10. #90
    USA
    Nice exhaust work. Are you going to add tips?
    The fake outlet could be made functional with a QTP electric cutout. I have one of these on my saabaru and have considered one for the 818. https://www.quicktimeperformance.com/OVAL/
  11. #91
    Jul 2014
    I wasn't sure I wanted tips i was going to paint and wrap the exhaust and go with that, I am planning to mesh all the openings and of course cut out around the tips and the muffler.
  12. #92
    Jul 2014
    well the paint is going on! just a few last panels at the painter but I had to sit a few in place to see what it looks like.
  13. #93
    Puyallup, WA
    Thats a great color for the car. Cant wait to see it all together.
  14. #94
    Freeport, ME
    What did you end up with for the length of the wiper link? I'm thinking that I can use a threaded rod in between the ends and make it adjustable. Your center to center length would give me a good starting point.
    Dan
  15. #95
    Jul 2014
    Thanks, the center to center I have is 5". I just used the stock linkage and cut it down to a 5" center to center and welded it together then bent the ends a little so the sockets lined up with the ball. It will be more than strong enough for sunny day to day. My car will not be seeing ice and snow to jam it up.
  16. #96
    Harley818's Avatar
    Vancouver BC
    I'm keen to see the finished car..... I'm planning a similar colour. What colour & Paint did you use? Sorry if you already stated.
    Harley
    Bought 2002 Donor Jan 2014
    First Start Jan 18, 2015
    First Drive Feb 14, 2015
  17. #97
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    I missed the sneak preview photos of the paint - love the color! It's the same color I've been wanting for mine, though I will likely do a wrap first to keep more immediate costs down. I can't quite tell from the pics above - is it non-metallic? What's the color called? Any shots of the completed paint job? Very excited to see what it looks like!
  18. #98
    Jul 2014
    I am still trying to finish the last few mechanical stuff before I mount the body.
    As for the paint it is called Cyber Gray Metallic. It is a GM color on corvette and a few of the other models. It does have metallic in it but is hard to see it in the pics.
    It also looks a little lighter in the sun.
    Its funny you mention cost. I did all the body work to prep, sanding, mods, fiberglass work, and primer. I just had a guy from work spray the base and 4 coats of clear for 1500 bucks! all panel painted. now mind you the whole thing has to be color sanded to remove a bit of fish eye here and there and a lot of dust nibs (not the best paint booth setup)
    here are a few pics one is of the color on a corvette
    Cyber-Gray-Metallic-Chevrolet-Corvette-Stingray-7.jpgStrathroy-Caradoc-20160221-00618.jpgIMG-20160221-00617.jpg
  19. #99
    Hindsight's Avatar
    Atlanta
    That's going to look fantastic. Looking forward to seeing it all assembled.
  20. #100
    Harley818's Avatar
    Vancouver BC
    you're holding us all in suspense here......hows progress with the paint?
    Harley
  21. #101
    Man that paint is awesome.
    Forgot you were in Ontario! I know were I'll go when my 818 is on the road!
  22. #102
    Jul 2014
    Sorry guys, I have gone away for work for a few weeks and have not got a chance to work it. it is all done and laying in the basement. I was working the mesh before I left, I got the octagon flat black mesh from customcargrilles.com it makes the vents look like the car is OE.
  23. #103
    Jul 2014
    USA
    That's some of the nicest looking mesh I've seen. Where did you find that?
  25. #105
    Senior Member Solidworks-Mike's Avatar
    Las Vegas, Nevada
    Based on the link he posted above, I'm going to guess this is what he got: http://www.customcargrills.com/prodd...?prod=Perf-Hex
    818-S 2.5L Turbo Chassis Number: 404
    Kit Order Date: February 19, 2016 Kit Completion Date: March 19, 2016 Kit Ship Date: March 26, 2016 Build Start Date: April 22, 2016
    Build Thread: Click Here
  26. #106
    USA
    Quote Originally Posted by Solidworks-Mike View Post
    Wow, I was really blind there. Two posts above mine. Thank you.
  27. #107
    Jul 2014
    well got a few more panels on and got the wheels and tires in as well.
  28. #108
    Denver, CO
    Looks great.
  29. #109
    Hindsight's Avatar
    Atlanta
    Very nice! Love the color.
  30. #110
    Apr 2015
    Andover, MA
    Looks great! Ditto on the color choice. Your dual hoop roll bar looks nice too! Nice job getting all of the panels aligned, gaps look excellent.
  31. #111
    Jul 2014
    alot of hours fitting and reworking edges to get it just right, making the vents bigger and moving the gas cap was the biggest time consumer.
    Harley818's Avatar
    Vancouver BC
    look great. I'm planning a similar colour so seeing yours is very motivating. Nice work.
    Hoping to paint in the next 8 weeks.
    Harley
  33. #113
    Senior Member Flamshackle's Avatar
    Aotearoa (New Zealand)
    Wel done on the exhaust settup. By far the nicest looking one IV seen here IMO.
    For me I'll be going single tip direct out the back. Lightest Weight possible is one of my goals.
    __________________________________________________ _____________
    That man is no fool, who gives what he cannot keep to gain what he cannot lose
  34. #114
    Jul 2014
    San Diego Ca 92106
    Bravo, your mods look outstanding. The double hoop roll bar looks so good on these cars. Can't wait to see the final pics.
  36. #116
    Hindsight's Avatar
    Atlanta
    Very nice!
  37. #117
    Senior Member AZPete's Avatar
    Very impressive work! I particularly like your innovative exhaust and the dual roll bar hoops. And, the paint, of course! However, I think your windshield support would complement your paint color if it is upgraded to black walnut.
  38. #118
    USA
    I love this color. Everything turned out great. Excellent choice!
  39. #119
    Very nice! The gaps on the body look great and even too. I remember that pic when you cut the rollbar and welded your new one, you've gone a long way since!
    Great idea that 2x4 to strenghten the winshield in case of a rollover.
  40. #120
    Jul 2014
    thanks for the idea on the black walnut, It will just blend right in! yes its coming along but still a ways to go, a few more things on the exterior and then I can drive it more then close up the interior.
