Results 1 to 5 of 5
Thread: Led flasher?
    nkw8181's Avatar
    Dallas, TX
    Led flasher?
    How is everyone wiring in the led flasher?
    Nolan
    Quote Originally Posted by nkw8181 View Post
    I went traditional.
    red is brake, run and turn. I will switch this to LED.
    The small white tail is reverse only with a standard bulb.
    Edit: Sorry it was early AM, I didn't read the question correctly.
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    I found the two blades on the flasher would plug into the original connector then just attached the black pigtail to one of my harness to chassis ground screws.
    Larry
    Feb 2014
    Asheville, NC
    Quote Originally Posted by K3LAG View Post
    Larry
    Same here. It works well from my experience
    Frank - Build thread
    nkw8181's Avatar
    Dallas, TX
    Thx, I didn't want to chase down the stock flasher so just bought a version that goes in line and got it to work.
    Nolan
