Results 1 to 5 of 5
Thread: Depowering rack
    Nov 2015
    Depowering rack
    Do y'all have a trick to get the steering rack taken apart? I am trying to take apart the rack to cut off the seal. I am stuck trying to get this threaded disk with 4 pin holes out. I have been trying making custom tools, but they are not strong enough and keep bending.
    Senior Member Solidworks-Mike's Avatar
    Las Vegas, Nevada
    There is some good info here, not sure if you saw this thread or not:
    http://thefactoryfiveforum.com/showt...hlight=depower
    818-S 2.5L Turbo Chassis Number: 404
    Kit Order Date: February 19, 2016 Kit Completion Date: March 19, 2016 Kit Ship Date: March 26, 2016 Build Start Date: April 22, 2016
    Build Thread: Click Here
    Senior Member Loring's Avatar
    Nov 2015
    Lakeland, FL
    Perhaps a spanner wrench will do it?
    818C | Kit delivery: 3/19/16 | Status: Powertrain installed
    Daily: 2014 CTS-V - Fat and slow
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Spanner wrench is what you need. You can buy one, or you can make an adjustable one like this: http://cdn.instructables.com/F6C/6B1...DKE2.LARGE.jpg
    Or you can put a small little drift in one of the slots and tap at it with a hammer.
    Freeport, ME
    I used a piece of scrap 1/2 thick aluminum and a couple of roll pins from the hardware store. Remember you only need to remove the rubber seal from the piston, you don't need to hack off the piston. Many people are satisfied with looping the lines.
    Dan
